Fs: S15 200sx Front Spindle (calipers/hub/rotor/upright), Lower Control Arms, Power Steering Rack, 14mm Bolts & Nuts
Calm down champ, was just asking. You have stated it had something so I just thought that you might have the info for it.
OK thanks for that, I'll do some probing on the weekend and clean up that wiring mess a bit, your hypothesis sounds logical, so I'll start there. Really appreciate the advice. 👍
I gotta agree that FP wiring looks, interesting. And questionable. I'd be doing some probing to see what circuit is shutting off. It actually sounds like FPCM wiring is partly in use. Priming, starting are all at full power from memory, then a few seconds later drops to half strength, and it looks like that signal isn't getting to your FP, as a hypothesis that is. Needs more probing on a multimeter being done.
HAHA yeah its been quite the experience sorting out the wiring, I had an auto electrician come and do some cleanup under the dash. Its a work in progress.
By TurboTapin · Posted
That wiring looks like it was done by a 12 year old with a methamphetamine addiction. Start by redoing that disaster. What you're describing has nothing to do with your FPR vac source.
