Hi,
Got a bit of a prob, rear passanger side bearing disintegrated, with it the seal, and apparently there's a spacer that goes b/w the bearing and the cover that holds the whole thing together
Can someone supply me with a diagram of how this thing is meant to be put together?
BTW, I'm in PNG, so going down to the wreckers is not an option
Cheers
KB
https://www.sau.com.au/forums/topic/267443-need-88-skyline-diffbearing-diagram/
In that case it's probably a local R31 with a live axle.
I guess the bearing your talking about is out on the end near the wheel eh!
If this is the case, the bearing you're talking about is just behind the axle mount flange. Correct?????
Cheers, D
And remember, it's a retainer, ie it retains the bearing on the shaft. More importantly, it retains the whole axle in the housing, preventing it (and your wheel) parting company with the car. Don't just bash the retainer on with a hammer. I'm inclined to think that if you need to ask questions on an internet forum, you probably should get someone more experienced to fit the bearings for you.
yea if aus r31 will b bw78 diff. will need 2 drop ur centre out and press off the old bearing. then just go 2 a bearing joint and match it up (dunno what auto places u have there?). just normal taper roller/plain bearing or something (cnt remember) nothing special. press new 1 back on and this ring ur talkin about is ur shim, it sets the backlash between the pinion and crown gear. goes between the bearing and diff housing will def need it.
should b pretty straight forward taking it out when looking at it.
take wheels off, slide disks off (floating rear), undo 4 bolt axle flanges, pull axles out, undo diff plate, undo 4 bolts on the bearing cups. then diff centre should just fall out, might have 2 jimmy it out with large screw driver etc...
close-ish just dw about the mini spool part. more stuff on that site\/
http://wiki.r31skylineclub.com/index.php?t...ng_a_Mini_Spool
Edited by OUTATIME
We've got the bearing out, that's not a prob, but my mechanic recons there should have been a spacer holding the bearing in place. and we need the part numbers for the spacer/retainer and the seal
The old bearing was in bits and pieces when we took the cover and axel out...
N
:):D What is it about people posting tech how-to articles and them filling them with crappy mobile phone photos? Even the most basic phone takes half decent pics now, and digi cameras aren't that dear (my son's $70 job takes fantastic photos). Sorry for the rant but I take tech photos and write tech reports for a living and this kind of thing just sh!ts me no end.
Now that's out of my system, I have a Nissan Service Manual, and there are no pics in there showing the rear axle installation. It does, however mention the bearing retainer ring which goes on the inboard side of the bearing. Note this ring is never to be reused, and a new one will be supplied with the bearing kit. Your mechanic is correct - there should have been one. don't fret if you can't find it, as a new one will be supplied (as long as it's not floaring in your axle housing somewhere :banana: )
The photo below shows a Mazda RX2 setup, which uses the same concept as all live axle setups AFAIK. note that the locking collar has been welded to the axle in the photo - not what I'd call good practice, but it's how I got the car. Apparently it was a common fix for early Falcon (c1970's) when the rear axles used to pull out whilst driving.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
