  • Replies 184
+1 to jezza on that! felt so cheap bringin a sprinter though lol nice to meet new people and those ive met before! nice cruise home, princes hwy for the win, hope this happens again soon, start organising b3za!
lol trust Jezza. :)
yeah good turnout, great night.
and the dude (tall asian guy) who rocked up late with the r33 4door, you will find a camera in your car, its those 2 dudes camera, the ones that rocked up by train.
hope you all got home with out and trouble. unlike me, followed these 2 skylines then realised they were the only 2 left and were in albert park..... not cool man
anywho sleep time, gotta be up in 5hours
blue r34 gtr and the 4 door with the gtr kit <3 i want!! also wanna laugh at the guys in the stationwagon doing a U-banger n flooring it in the wet, whoever didnt shout out hit the wall boo to you coz everyone did lol
Yeah I wanted to see that wagon get written off. He came sooo close to losing it.
Edited by jezza boii
lol i agree wif jezza man! hot hot hot! :) hahahha.. anyways, zaver, pm me your number and i will get daniel to give u a call reguarding yur camera. :mellow: lol sorry TJ!! jamie n i took the wrong turn, we were in the wrong lane and din end up goin into albert park lol.. roads were wet today man.. was all over the place when i tried givin it abit haha.. oh and that station wagon! wth man.. lol that was just bring stupid haha.. great night guys! we should have stuff like this more often!
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
