hey everyone,
Just sold my skyline, but it's getting towed down to adelaide probably on monday. Got a drama though it sits to low for any tow company.
So what i was wondering if there's anyone around my area (mechanic etc.) that wouldn't mind just quickly throwing it on the hoist and winding it to max height it has apexi coil overs. Alignment isn't a problem cause they'll be getting readjusted as soon as it hits adelaide.
Money or beers which ever is prefered to the help.
just reply here or give me a call on 0420 243038 if ya can help me out. Any recommendations for mechanics would be good to
cheers
Shawn
https://www.sau.com.au/forums/topic/267801-adjust-my-coilovers/
Why not just chuck the front bar in the car with the front seat(s) down? It's still a whole car, just the front bar is laying through the middle of the car.
Otherwise they may charge you for having an extra item to transport as it's space.
