G`day All,Looking for 1 or 2 NEO injector`s as i have 1 buggered so would like to have full set spare ,iam in PERTH so PM or call 0410020025,cheer`s chuckie.just a pic so you do know what iam looking for .post-36964-1241154998_thumb.jpg
https://www.sau.com.au/forums/topic/267934-rb25neo-injector/
I have a full set going cheap - make me an offer. Just confirming, they high impedence, 370cc, top feed for a rb25det neo.
Thank`s but i have 6 i is funked,so i have full set in car ,so as i did ask for 1 may be 2 if the PRICE IS RIGHT,payed $50 for 6 + fuel rail ,so may be $50 for Injector`s,cheer`s chuckie.
im in perth and have like 4 sets so pm me and come and get some
Hi iam still looking for injector`s so please let me know what your doing cheer`s chuckie.
G`Day All Iam STILL LOOKING for 1/2 INJECTOR`S as i can`t contact people that have POSTED saying they have some ,so IAM STILL in the HUNT some one must have 1/2 laying about ,cheer`s chuckie.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
