  • Replies 57
i used to own a towing business you will want too make sure you have the right insurence once to put a car on the trailer ..ie when i backed my truck up to a car and put the cable to whinch it up i was covered by what was called hook insurence .
so if the cable broke the car owner was covered . once all 4 wheels are the tray of the truck it was called load insurence both come under a seprate policey and 2 lot's of premuim's .
you may want to check this out b4 offering the service . also seening how your effictly towing a customers car you may need a toweys lincence .
this is the main reason workshops find it cheaper just to ring a tow truck . i would not want a car of mine on your trailer not knowing what is covered and by who if you prang or the car falls off on the way to the workshop .
not trying to put you guys off its hard to make a buck in these days and times and good luck with the workshop just making you aware of what you might be up for .
cheers dean
it costs me $110 to hire for 24 hours from any servo ive been to plus a $50 deposit which i get back.
id have a flat rate, then charge after a few km's if its say more then 30-50km that needs to be driven (1 way)
that way it should cover the trailer and the whatever the tow car's general wear and tear while towing.
i'd also be buying insurence that'll cover the workshop while towing incase something happens to either car.
who wants to play hang man
Kietz, I editted your 1st post for good reason.....keep slagging businesses and you are out of here permanently!!
You've been going good for awhile now (I even reduced your warning level) don't blow it now mate.
Which part of town you from?
If South, Caltex on Cross Rd. (261 Cross Road CUMBERLAND PARK SA 5041) charged me $85 last time i hired one for 24hrs which was a couple months ago now...
from port noarlunga mate.
ive used at least 3 or 4 different places , shell, mobil cant remember the others but each time its been $107 for 24hours plus a $50 deposit.
ive also used a shell up north near modbury and it was the same price.
maybe caltex is the way to go next time i take the track car out to lala.
also keitz, grow up mate.
My work (Rob's Fuels) do a car trailer for $60 + $50 deposit for 24 hours.. Didn't realise how cheap we actually were on that.
all insurance issues are being dealt with. as for general insurance on workshop and workmanship/public liability thats all done and up to scratch. Other than that hoist got up and running today and also got all the tools and welder in today, so we are pretty much ready to to buisiness as of tomorrow!
hope o hear from you soon
Good luck with the new shop Ben and Simon!
Im sure it will all go well especially with the high level of quality you have always put into my car in the past Simon
When i get my license back my car will definitely be down there for some things that need doing
:D Ceff man
EDIT: Was going to say don't be afraid to go down to the workshop/give them a call and have a chat about any ideas you might have :P
Edited by Ceffy_SA
Hey guys not sure if i put in address anywhere but on unit 3/26 stanbel rd salisbury plain. there is a workshop out the front called glenrothes mechanical. there is a driveway that runs down the side of that and we are second shed on the right
now open for business!
ok Ben and Simon. Thanks for ignoring my post above regarding becoming an SAU site sponsor, but if you haven't responded to me within 24 hours this post is gone and you get an official warning.
It is not fair for you to plug your business on here for free, when other businesses do the right thing and pay sponsorship fees.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
