*2006 GT white moutain bike for sale.its brand new brought it for 990 brand new back in the days seeling for 200 neg.nothing wrong wif it ,just had a fresh respary.no use for me to have it anymore
*heaps of soccer balls for sale selling for 15,worth in the shops between 30 to 50.brands vary in from adidas to nike to lotto
*an 2009 24inch moutain bike for sale for 30 dollars.in the shops brand new in box worth 250.unwanted chrtmas present
*an 2006 redline bmx bike selling for 100 brought it for 700 back than.nothing wrong with it.still goes fine
contact anthony on 0408 332 900
or pm
Edited by ITA-JET
https://www.sau.com.au/forums/topic/268191-stuff-for-sale/
  • 4 weeks later...
*2006 GT white moutain bike for sale.its brand new brought it for 990 brand new back in the days seeling for 150 neg.nothing wrong wif it ,just had a fresh respary.no use for me to have it anymore
or pm
https://www.sau.com.au/forums/topic/268191-stuff-for-sale/#findComment-4696623
*2006 GT white moutain bike for sale.its brand new brought it for 990 brand new back in the days seeling for 120 neg.nothing wrong wif it ,just had a fresh respary.no use for me to have it anymore
*an 2008 haro bmx bike selling for 400 rrp 690.candy apple,new socket,new chain and brake cable and rim.got recipt
or pm
https://www.sau.com.au/forums/topic/268191-stuff-for-sale/#findComment-4708233
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
