hey guys
i have tried to search up about this but cant find anything clear on what steps u have to take to get the transfer over from nsw to vic.
im looking at buying a new car but its got nsw plates on it.
i know i have to get a road worthy cert but does vic roads have to inspect the car as well?
if anyone has been through this any help would be much appreciated =]
my main concern isnt getting the road worthy just want to know if vic roads have to check over the ccar
cheers
https://www.sau.com.au/forums/topic/268200-transfering-rego-nsw-vic/
Hey Tin,
they will look over the car, but solely to check the numbers.
All you need is an appointment, a RWC and a declaration of sale from the previous owner. Make sure that includes his license number, date of birth and current address.
Good luck, bruv!
When I did mine, I let the rego run out in NSW before organising VIC rego, however:
I had a road worthy done on the car by a Vic Roads accredited centre within the 30 day limit. I took the road worthy to the vic roads office and told them it was a new registration, along with the receipt from sale (just a word doc the seller and I signed).
The lady asked how much I wanted to declare the car for even though the receipt told her. I paid my 12 months VIC rego plus stamp duty and the $90 to put my plates back on. Was just over $2K from memory.
To get the remaining rego back from NSW, I believe you need to apply to the RTA up there like you would normally do for Vic Roads down here. You don't transfer as such.
I walked out with a VIC registered car.
HTH :P
**Edit - just saw post above, they don't need to see the car, that can come up if there are any questions over the value but definately don't need to sight it. Sighting the car is more common on first rego, e.g. after compliance.
thanks guys for the help so far.
so really i just need a RWC, make an appointment and pay for new 12months reg, stamp duty is that correct?
cause the thing is the sellers rego runs out in 2 weeks =/
and say if i cant get the rwc in time that would prbly mean vic roads would have to see the car right?
Yes you are correct
If you can't get the RWC in that time, yes potentially they may want to see it as when it is does eventually get a roadworthy, it will be unregistered. I am not 100% sure if when renewing NSW rego, the car needs a pink slip at the same time but possibly get the seller to renew in NSW to buy yourself some more time then just cash the rego in up there when you are ready.
I wouldn't have thought you would struggle to get a RWC inside 2 weeks though down here, waiting lists in my experience aren't that long normally.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
