Go the S13 Silvia.So many people go spending a fortune on AE86 Sprinters trying to be initial D...Not a good budget drifter in my opinion. Why bother when an S13 comes with the SR20 and beefier Gearbox and diff standard.Whilst the Sprinter guys have gotta spend and change pretty much everything...S13 All the way
180SX and R32 are the easiest to find a decent one but will probably take all ur budget. Could get a NA silvia but not as easy to find good manuals and wouldn't be as fun as you'd have to work harder to slide it (unless you find constantly holding WOT and kicking ur clutch like it's ur pregnant missus fun, then you will love it).
Either way, whatever you get, make sure it has coilovers and a mechanical diff as the basics. A good race seat and deep dish steering wheel (or bosskit spacer) will let you get a good driving position/hold you in place while sliding. That is almost as important as mechanical mods.
S13
Cefiro
R32
R31
My mate started with an R32, but that had a built RB25 in it. He came 2nd in the WA Drift Final Battle yesterday, not bad for his first season. The car started off as a daily, turned into a full blown drift car.
My other mate is buying a Ceffy for $1500 as a rolling unregisterable shell, and putting an RB25 engine/gear box in it. Will come in way below $10k
I'm buying an R31 for a bit of fun. Weld the diff, strip the interior and add some coilovers. Will be a lot of fun, and I'll add extras as I go along.
Plenty of options for you, just think it all through properly and you should make the right decision!
hey bd_89 have u had any luck looking through the for sale section??
came across this bad boy yesterday,
http://www.skylinesaustralia.com/forums/27...ri-t266391.html
could be what your after though maybe a bit over the top i dont know, it looks like the brakes, suspension and engine are all taken care of for ya.
anyway some very helpful suggestions in here, i just thought this sounded like what you might be interested in and around your price range :D
good luck with it mate.
anyway some very helpful suggestions in here, i just thought this sounded like what you might be interested in and around your price range :)
Hey,
Yeah ive had a look on a few forums and carsales. Seen a couple of things that are interesting just not in a position to buy for a few months (licence is on vacation). Was just interested in what people would recomend so i could figure out how much i need to save also was thinkin maybe s15 and use as a daily/drifter but the 20g+ price and the thought of bending it dont go to well.
buy my r32, i wasnt planning to sell it but just bought a house and need to focus on that at the moment.
i have been setting it up for drift, but havent actually drifted it.. and with oran park closing down, im turning my attention away fom drift and more to superlap, so a gtr build up is in the planning.
cusco coilovers, hicas bar, cradle bushes, all coolant lines, radiator and thermostat, waterpump replaced, head pulled off and checked, replaced head gasket, safc 2, 300zx afm, kakimoto turbo back exhaust, hdi fmic, 122000kms, 100000km service done, bought as a complete stocker in october 08, sept 09 rego.
its in your price range :D
pm me if your interested at all.. im happy to hang on to it for a while, when it sells it sells. it wont be getting driven much.
cheers
Linton
cheers
Linton
Lol, still gotta sell my car buy a GTR and then wait a few more months till i have enough for a drift project, thanks anyways though.
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
