Hey guys have the following parts for sale. Would prefer P/U's in Brissy, but i guess most of the stuff i have, can be posted at your expense.
Fuel pump $100
Fuel Door $40
Fuel tank $80
Passenger Door (complete) $150
Rear Rio Bar $50
Rear bumper $200
Rear Tail lights Pair $100
GTR headlights (pair) $200
Rear boot lid (wing + badges) $200
Fog Lights (Pair) $50
Front Bumper (2x cracks) $180
Side Skirts $150
Set of Side Pods $100
Right F guard (damaged) $150
Left F guard (perfect) $300
Left Front Guard Liner (perfect) $50
Rear GTR coilovers $150
Front Trust Coilovers $200
Aluminium Bonnet $250
Rear cradle $350
Tailshaft $200
Rear sway bar $200
Front sway bar $100
Front LCA (pair) $200
Front Upper Arms (pair) $100
R32 GTR Diff $800
Complete boot trim except carpet $50
Handbrake cable + assembly $80
Dash surround with digital clock – $100
Twin BOV’s with manifold piping to suit - $150
L+R Window door rubbers $70
Full floor carpet $50
Bonnet catch latch $30
Give me a call on 0431657139 if your interested. Everything in good nic, off a car that done 77xxxkms. Let me know.
(also have a GTR front cut for sale, engine, gearbox, clutch, ecu and loom) open to offers $6000
https://www.sau.com.au/forums/topic/268525-r32-gtr-parts/
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
