just be careful with mega CC injectors and low rated or normal size pumps
the issue here is that, if it leans out, and your on full load (typical)
then your AFRS plummet off the planet and the engine goes bang
youll have very little warning / chance to save it, if this occurs
so, if you install mega CC injectors, you are taking a big risk by keeping a low rated pump
your risking a $10k+ setup for the sake of $400 ish on a larger flowing pump
the pump wont fail, and if it does, this is ok, as fuel stops flowing, the engine stalls
the issue becomes critical when not enough fuel flows, ie ; the pump cant keep up
the engine has enough fuel to keep running, but the AFRS plummet and it goes bang
so Nosure - your pump wont fail, and if it does, thats ok, the tuners concern is, if it cant keep up demand, then its bad
I have nismo fuel pump, and 800cc injector. run 1.28bar, make 312kws on all 4. the tuner told me this is the limit of this fuel pump. if go up boost, the afr will leaning out. now the afr is between 11.5-12 which is safe. but my injector duty only about 70%. tuner suggest me replace a fuel pump or surge tank setup.
does that mean my nismo fuel pump failure? or it was really tue limit of nismo fuel pump.
my car is gtr 34.
you can make that power on stock 440 injectors and stock pump
So you have one of 3 likely problems
1. The pump is dying
2. The fuel filter or something is blocked
3. The pump isnt wired correctly
Its a likely story that its #3 - so often people post up here about lack of fuel etc only to find out the pump is not wired correctly with the required voltage
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
