i found the proto type i made, it gives you a good idea what im talkin about but looks rough and dosnt have the airflow sensor hole this is the bottom half the top looks the same as the pics above or for a little extra can be clear like mine.
also the bottom can be conected to a duct runnin to the front bar.
i have moulds for two differant boxs one with standard piping and intercooler and one to suit front mount
i would expect about $150 for one to suit standard & 200 to suit front mount as its bigger that would include postage within oz
i can sell these boxs but so far ive only had fuct coments not one person said "id be interested" or i would be making more right now give me ten min to pull mine out and i will have the pics up
i am interested mate. thats why im reading this thread. like munkyboy said, all we are looking for is pics of how well it fits, and a price. no offense meant
none taken !
the air box pictured above is to suit front mount it uses a 3" cold air feed from the bottom but as this was the proto type
the holes arnt cut out.
im not sellin these to make money selling them to help yous out as i searched for ages and couldn't find one so thought id make it .
sorry the one in the pics looks scaby but im not pulling my car apart just to sell more i couldnt care less if i sell more or not.
if i do sell i promise the finished item is much better looking fitts straight in wth no mods or if your not happy money back im not some rippoff out to make a buck
yeh jokes funny haha
"i got jokes".
well i guess no one is realy interested in these airboxs. i mean a plastic partition is just as good right?
"yeh right"
i also love how the plastic partitions start vibrating at about 140ks makes a mad sound and leaves awsome rub marks yeh mad might go back onto ebay and waste $90 on one now
Edited by ELMOHASA33
hahah calm down man
fark
we asked you to show us the box, so we could see the quality and look etc.
because ive seen ppl try and sell crap on here for large amounts of money before.
and my airbox is very nice thanks. its a single piece of perspex, cut and shaped to snuggly fit the space around the pod.
its not sealed at the bottom, but then why would it be? thats another avenue for cold air to get in.
and it gets its air from a 3 inch tube running from the front bar into the box, from underneath. non of this snorkel bullshit.
btw, the snorkel does not see direct airflow coz its blocked by the bonnet, therefore the air needs to be sucked in to get into the box. so you need a 100% sealed box to use this method, like the standard filter box.
and after all that trouble, you still dont have as much cool air coming in, compared to an open 3 inch tube, not to mention that the snorkel may interfere with your aftermarket intercooler piping.
these air boxs are fully sealed and can run the 3" pipe at the bottom or the original snorkle or both depending on the intercooler piping.
oh and they are about twice the volume of a standard box
HI ALL RECENTLY I FITTED A K&N FILTER TO MY R33 AS I LIVE IN THE BLUE MONTAINS (NICE COLD AIR)
IT MADE A SLIGHT DIFERANCE UNTIL THE CAR WARMED UP THEN IT WAS BOUT THE SAME AS THE STOCK FILTER THEN I TOOK IT TO THE CITY AND I COULDNT BELIVE THE AMONT OF POWER IT LOST I FITTED THE FACTORY AIR BOX BACK IN AND BACK TO NORMAL THE PROBLEM WAS THE 100 DEGREE TURBO PLUMBING BEING RIGHT UNDER THE AIR FILTER I BOUGHT A CLEAR PLASTIC AIR BOX OFF EBAY BUT HAVING NO BOTTOM IT ONLY MADE THINGS WORSE SO IN THE END I MADE MY OWN AIR BOX WITCH FITS THE K&N POD INSIDE AND HAS A BOTTOM TO SEPERATE THE INTERCOOLER PIPING FROM THE AIR FILTER ITS MADE SO MUCH DIFFERANCE JUST WONDERING IF EVERY ONE ELSE FOUND THIS TO BE A PROBLEM AND IS THERE ANY COLD AIR OR AIR BOX KITS FOR THE R33 IVE ONLY SEEN THE TVR ONES WITCH ARE ALSO SUCKING STRAIGHT UNDER BONETT AIR ....
REASON I ASK IS I STILL HAVE MOULDS SO IF ANYONE WANTS ONE I CAN MAKE MORE
I want one! lol, got a fmic and a pod too, but dnt really wanna get rid of the pod, how much wud u sell me a mould for?
i probly wouldnt sell the moulds but a finished box with the cleartop like the one pictured would be $200 posted to your door i think thats pretty fair it takes about half a day and $60 in products to make one.
it would be finished though not like the one above.
including bracket to mount to original air box location.
  • 3 weeks later...
man im dead set interested in one of these, ive got a r34 gtt with rb25det
would this mould fit into one?
if so consider one sold.
ive got front mount so only need a hole for afm and the induction pipe opening for turbo.
pm me.
cheers, Bass
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
