Hey all,
Looks like I just spun a bearing in my R32 GTR, so I am either going to sell it complete or part it out and sell it, Cant be arsed going through a rebuild ... again.
Will post pics later today,
Interior complete, infact whole car complete at present.
Open to offers. would like 15k for the car complete but open to offers, otherwise let me know what you are after off it and we will go from there.
Heath
https://www.sau.com.au/forums/topic/268811-r32-gtr-complete-or-parting-out-eoi/
SOme details on the car? I am guessin black? But could be interested on the complete car. So what i need to know is
Currently registered, until when
General condition of car?
What year model?
ABS?
Mods/wheels/brakes/ECU/turbos/shocks?
Hey guys, here are the photos, you will have to excuse my photography.
The OD has over 70k on the clock however it doesn't read accurately so was probably wound back in a previous life.
The motor was rebuilt only about 6 or 7 thousand K's ago, just enough time for one service... it has a 33 crank, N1 oil pump, tomie head oil restrictor, tomie sump Baffle kit, new timing belt of course, and so on Also the turbos were hi flowed and steel wheeled just before I bought her, although I never boosted above 6 pounds because I could never work out how to use my boost controller :))
Adjustable coil overs : brand is NFU or something by memory they made for a stiff but excellent ride.
Condition of the car is good all over other than a bump some as swhole but in my rear bumper wich marked the left quarter as well, otherwise the interior is in good shape all vents intact :O... the gear nob is worn though and the surround that goes around the stereo and shifter got cracked a little while back :sick:(
The car has 33GTR rims,
a MINES ECU
GREDDY boost guage and HKS EBC controller
and a turbo timer.
and Nizmo strut braces front and rear.
also a 3 inch zorst all the way through.... flowy but a but loud for my taste to be honest.
The car is mechanicly excellent accept of course the bottom end of the motor, I will pull the motor this week I think to see how bad the damage is and if the crank is salvagable or not.
Anyway, any other questions please fire away.
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
