  • Replies 131
So did my car.....when running through the hills, my temp gauge on teh dash showed really close to cold (like it is when u first start your car). By that stage the car had been running for about an hour......maybe just the cold air temp =\ altough it did warm up soon after.....weird
Had fun in the family wagon :P i was navigating in the grey stag that everyone was following sorry we took 1 or 2 wrong turns, did anyone see the 'baby on board' sign in the back of the unmarked cop car
I missed the turn off mundaring weir road and on my way back to the turn i went past the undercover car he had pulled someone over on the other side of the road i was going about 130 lol shat myself when i saw the lights then realised he was writing on his bonnet and booted it.
redhr32 i think you were following my if i was the red 34
i think my car was the only red 34 i saw on the cruise
either way it was a adventure
Hank i didnt meet you =[
Only person i met was Kerr (Rob) dude nice car!
SOOOOOOOOOO that was you that got me lost then hey, lucky we didnt drive to bickley or wherever that road went lol, all good fun...
I would have PM'ed to find out about the location but I only registered after a mate of mine told me about it. I was there in Saturday night in my WRX. Was my first cruise since moving to Perth so I was just asking to find out where I was meant to go and I want to thank Hardcore Princess for helping me out.
Cheers for whoever emailed me the map hey...
Seriously shat myself on Rockinham road when that undercover cop pulled over the dude in the 32.
"Finally! A wagon's caught up"
"Dude that's a massive gps system"
"And a massive antenna"
"Guys is that an undercover?"
"Pfft. Definitely not... BUt seriously imagine if it was, who would you-"
*Lights start flashing*
*Siren goes off*
So worried, sitting there with 8 demerit points 'n' all...
if anyone wants to go on a smaller cruise, just a few friends and wants to tag along or whatever then give me a yell im often in my car :D
Well i'm up for small cruises any night when im home :) even during the day hahaha love having 1 week on 1 week off :D
haha rofl that was you, i was directly behind u and i merged to let this dickhead who was up my ass pass and saw my mate in the integra dropped way back and i knew something was wrong and saw lights flash 100m down the road, quick right and a few lefts soon followed. heart rate through the roof :D dont have a demerit eraser u know!
^^ if you ever see the yellow integra or hear it more likely i wont be far just give us a flash and follow :D
Edited by Davidsdh
Yeah sorry, bout that. Saw you turn up and I got a map off the guy you were with but you looked busy so I thought I'd say hi later when you weren't handing out maps. Then I went to speak with some people and ended up leaving the cruise! Ah well, next time I guess, we shall share some R34 awesomeness.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
