Hey Guys
Im now putting my skyline up for sale, like in the description its a silver r33 gtst series 2.
i owned the car for about 3 years now and i have really enjoyed her.The car has an idling problem and the front drivers has its usual tear in the seat.Also the car has been in an accident with repairs done in sydney, somebody decided they wanted to merge into my car? then continued to blame me...needless to say his insurance took liability but thats story is for a rainy day.
It has NSW plates until august 2009 but it is in Queensland as i just recently made the big move and havent had the time to change it over.Which just last week went over 100k
I consider the car stock with a few add ons......really wanted to build a beast so started with the normal mods.
Splitfire Coils
Stainless Split Dump/Front Pipe- jus jap
x-force 3" stainless hi-floiw cat- jus jap
cooling-pro stealth intercooler- just jap
Apache deep dish rims 18"- St George Tyres- Sydney
Things that came with the car
Apexi engine checker
Hks electronic boost controller
turbo timer
AUDIO
Kenwood deck
6" front doors
6" rear parcel
7x10 in back seat where you rest your arms on the side
600 watt 4 channel amp
Has white noise ive tried to ground it properly but no luck.
Things wrong with car
Idling problem
window switches
electric windows need playing with.
drivers side electric mirror does not fold in...only just started to do this
but both mirrors do operate normally.
needs the 100k service done
rear demister not working...this only just started to!!!
In all i still love the car but the missus hates it... only reason im getting rid of it is because times are tough and need some cash but if it doesent sell its no biggie either.
Im looking for around
10k for her
if i missed anything or you want more pics please ask
Please text or call me on 0404172797
or pm me
cheers
https://www.sau.com.au/forums/topic/269021-silver-r33-gtst-series-2/
  • 4 weeks later...
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
