They no longer do E-class licenses, the "Double or Nothing" rule has taken over. They give you a full license, but youllse a demerit point within 12 months you'll lose your license for double the original amount of time.
I'm not sure if you can do it on P plates because if you lost your licence while on Ps, you have to resit your practical test before getting your license back.
https://www.sau.com.au/forums/topic/269092-e-class-license/#findComment-4583780
i lost my license a few months ago (have 3 1/2 weeks before i can go for my L's again) on my P-plates, was on green P's aswell...You have to reapply for your L's, so sit the first test, the 30 questions one, then your driving examination, then the HPT then, you have your P's back.
https://www.sau.com.au/forums/topic/269092-e-class-license/#findComment-4583830
Correct.....
https://www.sau.com.au/forums/topic/269092-e-class-license/#findComment-4583992
If you lose your license for 3 months, and gain any demerit points during that period(3 or 6 months typically depending on the offence. 3 months for general loss of licence, 6 months for reckless) then your suspension will double (so 6 to 12months etc).
Incorrect....
https://www.sau.com.au/forums/topic/269092-e-class-license/#findComment-4584071
Damn, news to me though just checked and saw this 'good behaviour period' as outlined here
http://www.dpi.wa.gov.au/licensing/yourlicence/15639.asp
I'd rather lose my license for 3 months, then get all my points back so I won't have to stress for 9 months. Considering the lack of TEGS on the road, you'd just be unlucky to be nabbed for driving without a license.
https://www.sau.com.au/forums/topic/269092-e-class-license/#findComment-4584925
I've been told pleading your case in person to the DPI can lead to e-plates. dont quote me on that though, was told about it a couple of years ago.
I just got a letter saying I can only get 3 more demerit points before losing my license, and it outlined the whole double or nothing thing as well... sigh.
https://www.sau.com.au/forums/topic/269092-e-class-license/#findComment-4595484
dont have to do the hpt mate, i lost my license in oct and only got around to getting it back a month ago.
I passed the theory on friday and practical on a saturday but they dont process it until mondays, i thought i had to do the hpt, so i was driving round on monday shit scared of getting a 9month driving without a license suspension. But when i got to the dpi on monday arvo they said yeah all good go for it, I was like wtf and they told me you only ever have to do the hpt once.
https://www.sau.com.au/forums/topic/269092-e-class-license/#findComment-4601209
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
