Make/Model: Nissan Skyline S2 R33 GTS-T
Year: 1997
Kilometers: 119,XXX
Transmission type: Manual
Engine: RB25DET
Colour: White
Modifications: Turbo Back Exhausts Pod Filter, Xtreme Cushion Button Clutch
Roadworthy Certificate: Yes
Accident History: Minor on FL Crt Panel and door, was fixed up over a year ago, no suspension or structural damage was made
Asking Price: $13,500 O.N.O
Contact Details: pm for contact number or email me [email protected]
Other Comments: I have had this car for nearly 3 years since it was delivered into Australia, I have kept it as stock and clean as possible besides from the turbo back exhaust, pod filter and Xtreme Cushion Button Clutch, still fitted with standard side mount cooler and standard suspension, it has been fitted with white 17" rims, 235 front 245 rear can fit 255 easy,
Sony DVD/CD/MP3 player, separate pop out screen
2 gauges fitted in a pillar pod (Boost & Air Fuel)
comes with rear pods, (just need to be resprayed and fitted)
Just serviced
Reason for sale is that I want to get a 4 door car, I dont want a r31 as I still have 1, I would really like to buy a manual chaser
More Pictures can be supplied if needed
https://www.sau.com.au/forums/topic/269176-vic-1997-s2-r33-m-spec-gts-t-4-sale/
  • 3 weeks later...
gday mate would u swap my vt plus cash ur way?
this is EXACTLY what im after maybe we can help each other out a bit
my car isnt manual but still maybe we can figure somethin out
http://www.skylinesaustralia.com/forums/Ho....html&hl=vt
  • 1 month later...
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
