http://www.nismo.com.au/More%20Pics/r32%20...0gtst%20bar.jpg
thats the "bomex" bar UAS. Its kind of similar, but not exact, and this in particular doesn't do alot for me...Ill speak to some ppl later this week and see if they have any ideas where i can pick 1 up from.
The next option is to buy from here,
http://www.takakaira.com/php/template.php3...p3?id=538&cat=1
though the bar you like, comes in at 2k :(
https://www.sau.com.au/forums/topic/2693-bomex-kit-clones/#findComment-48810
