found this, dunno if it helps:
http://www.transport.sa.gov.au/pdfs/MR2.pdf
Thats a form to register an unregistered car, eg permit. Very useful but im looking for a long term solution solution as permits are only valid for a maximum of 3 days.
So it turns out its not too hard too get but you must compete in 1 Rally each year to keep the licence. The only tarmac rallies in SA are Classic Adealide and ASP or something similar too that. Both off which are not something Id usually do and easy/cheaper to just get permit.
There was a porsche with Rally rego that came from SA that did the Dutton Rally when I did it in Nov 2008..
Could look at doing a "tarmac rally" interstate like Victoria or NSW..Australian Tarmac challenge is a good one to do :)ATC Click on me!!!!!
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
