Yeah my grandads mate is one of the instructos, not sure if you know him as i believe you know my grandad/ maybe/maybe not depends if you are the Brad im thinking of :D
Anyways the instructors name's Kerry, he rolled an evo at targa west though maybe we shouldnt listen to him :)
Kerry Wade ? Who rolled Ross Dunkerton's Evo at Targa ?
  • Replies 53
Kerry Wade?
hey guys, ima noobi in here...you talk of members and public members, how do you become either? i take it because im new im a public member right?
i pick up my R33 this weekend, cant wait, im really keen to get on a track anywhere so i can learn to drive this thing, any info will be greatly appreciated,
cheers,
Gonz.
Yeah Kerry Wade, I spent a bit of time helping fix that evo, welll I handed people tools and kicked the tyres a little.
Nah I was just joking, I'm aware he's a great driver. Owns a bridgestone in Cannington I believe with his business partner Graham?
cheers,
Gonz.
Hi mate,
This will be a SAUWA club event, of which members of the club are given preference to the event. You can join the club if you want, link http://wa.skylinesaustralia.com/sauwa.php
If you just want to remain a public forum member, then you could participate in some of the public events that AHG run etc.
Cheers
Paul
Hi mate,
Cheers
Paul
ok sweet, thanks for that Paul, i think i will join then...so you guys organise things like track days at Barbagallo and hill climbs at Wanneroo and the like?
Gonz.
Gonz.
The first of the AHG Driver Training events is now up in the SAUWA Members area, with the possibility of running a second event if there is enough interest.
A number of the SAUWA Members do track days at Barbagello, but we do this with the No Limits Car Club http://www.nolimitevents.com/, as you need about 35+people to break even on the cost of an event like that.
There are alsp HillClimb runs etc at Jack's Hill, but they are also run by other clubs.
Cheers
Paul
Definately interested in an AHG day or 10 ........... Would love to get out there and learn the capabilities of my car in a safe environment. Barbagallo sounds win and skidpan day sounds awesome. I'll keep checking back to see the progress, cost and what not and if anyone becomes of it I am definately in.
-Chris
Any news on this. Numbers yet? Any possible dates or number of spots filled/left?
Obviously you need to be a SAUWA member first.
If you don't want to join the club, then you're best off calling AHG directly to see if they have any open events happening soon.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
