Hi everyone,
I just got a power FC put into my 33 GTR, however its just sitting loose there and you can hear it bouncing around whenever you hit boost or you go over speed bumps. i dont want to damage it and its also quite annoying.
can anyone please advise how they have mounted it? whats the best way!? apparently they dont have brackets -
i have tried velcro but you can still hear it shaking around side to side because the one part i can stick it onto is really thin.
would love to get some advice how did you guys do it? and do you have pics?
any help would be appreciated.
thanks all!
Hi mate I had the same problem in my R32, I tried the velcro it worked for a week or so but just kept falling off after that, so what I ended up doing is joining a few cable ties together and placing them around the PFC and through the standard bracket bolt holes and pulling it tight, if that makes sense.
Seems to work pretty good but took a bit of fiddling around to get it right, cable ties are dirt cheap anyway so its worth a try :)
My tuner used the high tech "stuff a rag in next to it" solution to stop it moving :)
I heard of another tuner using a folded up page torn from last month's workshop calendar, which provides the owner with the added bonus of a free picture of a girl with impossibly large breasts next time he takes his ECU out.
One of these days i'll pull the kick panel off mine and mount it properly.
Yeah mine's just tucked in there as well, but was tucked in quite well, haven't noticed it moving...
Weird how brackets don't really exist for it hey... :)
Might have to make some!
Take the back off the standard ECU with the mounts on it. Slot the holes slightly to fit the PowerFC case. Job done :)
hey guys, thanks for all of your replies.
i've still got the original mounting brackets, was thinking about it today - will probably just see if they fit width wise and if can tape it in or something.
i'll try and give it a shot tomorrow - will post results.
Edited by KR4-GTR
all done guys, i just redid the velcro with the hardcore GENUINE velcro stuff from bunnings.
also put a bit of the softer bits on the bottom sides of the power fc to pad it up and also stop it from rattling metal to metal.
its stuck on pretty hard - doesnt look like its going to move (touch wood)
attached a pic for those who are interested :)
cheers for all the help, reassurance and suggestions!
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
