I nearly went for hi flow but thought of future wants and needs so i opted for bigger turbo.
So dr drift tuned your ECU, what the rough price for that job?
As for EPA, i know. hehe o well we all take risks.
Not sure.. but all mods was done by previous owner..
Ill say $600 tho..
I got EPA'd/Defected and needed engineering cert.
Car is stock as a rock now..
But everything is going back on next month and retune..
Good luck with whatever you decide to do :blush:
  • 1 month later...
Just an update on the car:
I will leave these modifications as is:
-Split fire coil pack
-Full exhaust
-K&N filter
-Apexi Cooler
-Greddy blow off
I installed:
-Gt3040 AKA Garrett 3082r(top mount), manifold, external wastegate (40mm)
Installing in process:
-Bosch fuel pump
-Blitz boost controller
-550c Blitz injectors
-Nismo adjustable fuel reg
-Z32
-Apexi PFC
All i need is z32 and my car is ready for a tune. Hopefully ill find one soon so i can get the car tuned. I am aiming for 270rwkw with safe tune.
Question time:
I tried running the car using MINES ECU with the new turbo set up and the car was not running properly, wasn't idling properly, would drop to 400rpm and jump to 1600rpm, and would lose power when driving which was weird? What does everyone think, will the PFC fix that or is that something else that i should look at?
different afm, different injectors and your trying stock or remapped ECU's ?
and you wonder why it doesn't idle.... ?
please either dont drive the car or install the PFC, set the AFM, set the injector correciton and baby it around until you get it tuned properly
dont even bother loading it up, or bringing it on boost, its likely to be unsafe and you'll break something
No Paul, all i did was replace the stock turbo with gt3040 turbo. Didnt install anything else (pump, AFM, PFC, injectors).
My understanding is, the car should idle normally...but its not? So that's a bit of a worrie for me.
My car is getting the Bosch pump, AFM, PFC and injectors installed next week hopefully.
expect some lag aswell mate, should of gone the .63 exhaust housing to keep it a bit more responsive on a stock engine
i had the same turbo on my 33 and similar set up but on a forged engine and made 327rwkw at 19psi with no more than 20 knock level
what manifold u get??
What mods were you running to get 327kw, thats huge!
How laggy was yours and when did it come on full boost?
As for my manifold, i bought one off ebay as i couldn't find one. Not too bad but not the best.
just a forged engine
cp pistons,
eagle rods,
hks 256 264 cams,
greddy exhaust cam gear,
hks 1.2mm head gasket,
crower valve springs,
nismo 550 injectors,
bosch fuel pump,
tomei fuel reg,
power fc
garrett gt30/40
x force high mount manifold
turbosmart external gate
fmic
with cams it wasnt that laggy, full boost by 4,500 rpm, couldnt really see, too busy holding on
but when it hits boost it hits HARD!!!
watch out for stainless steel manifolds coz they are prone to cracking around the welds
i now run a garrett gt35/40 on a low mount 6 boost steampipe manifold with hks 700cc injectors
  • 3 weeks later...
Update:
I installed:
-Bosch fuel pump
-550c Blitz injectors(cleaned and checked)
-Z32
-Apexi PFC
-z32 with Apexi filter
Tuning has started but was aborted as the clutch started playing up and slipping. At 10 psi car made 170KW at 4000RPM. After that the clutch didnt hold up at all.
Made up my mind to go with Heavy duty cushion button. Tuning will resume as soon as the clutch is in.
Also gonna install: King springs for bit of better handling, and lower the car a tad bit, front strut. Turbo timer. Alarm. And car is done. Cant wait to finish.
Opinion and comments are welcome!
    • Plazmaman 76mm Pro Series, done. Data to back it up, I posted up somewhere here a few years back
    • So.....wire it up appropriately. You can't use the resister pack with those injectors anyway.
    • that’s the thing i’m on ID1050s and haltech not getting power due to the injector resistor
    • ahh okay cheers, i was thinking of just going for the m073, think m079 would be way too overkill considering they are same size.
    • My first car was a HG. I'm very familiar with them. A mild cam upgrade is a good idea. The 186 is a very flexible engine - meaning it has good torque from down low. You can give up a little torque down low for quite a lot more excitement in the mid range, and a bit more up top - but they are not exactly a rev monster. You need to upgrade valve springs at the minimum. For a bigger cam, you'd want to make sure it wasn't still running the original fibre cam gear. That would be unlikely, given that most of them shat themselves in the 70s and 80s, but still within the realms of possibility. Metal cam gear required. Carbies are a huge issue. The classic upgrade was always a Holley 350, which works, but is usually pretty bad for fuel consumption. The 186S had a 2 barrel Stromberg on it that was very similar to the one on the 253, and is a reasonable thing if you can find one, and find someone to help you get it set up (which is the same issue with setting up a 350 to work nice). The more classic upgrade was twin sidedraught CD type carbs, or triples of same, or triple Webers. The XU-1 triple Webers being the best example. You can still buy all this stuff new, I think, but it's a lot of coin to drop. And then the people able to set them up are getting fewer and further in between. There's still some, but it used to be everyone's** dad and uncle could do it. **Not everyone's! But a lot. All in all, I wouldn't get too carried away with the engine. Anything you do to it without a full rebuild for power and revs will only make it slightly faster. I am all in favour of a complete teardown rebuild, with nice rods and pistons, 10 or 10.5:1 compression, and a clean port job with at least a big enough cam to run 98 with that compression, if not bigger. And if I did that to a dirty old red motor, I'd want to inject it too, which I'd struggle to fight against the devil on my shoulder that would argue for ITBs and trumpets. But the bills would start to mount up, and it will still never make stupid power. OK, a few people still know how to build absolutely mental red motors, courtesy of the work that went into HQ racing and modern knowledge being applied. But even a 300HP red motor is no match for an RB20 with a TD06. So you have to decide what it's worth to you. I'd just put a set of 6>2>1 extractors, a 2.5" exhaust and an electronic ignition conversion/dizzy on it and just run the old girl like the fairly slow old girl that she really is.
