AS NEW CONDITION, THIS MODEL IS UNRELEASED IN OZ, NOT TO BE CONFUSED WITH DEH-P80RS!! THIS UNIT ALSO FEATURES A COPPER CHASE FOR CLEAN PUREST SOUND QUALITY. THIS MODEL IS ONLY AVAILABLE OVERSEASE BUT WORKS WITH AUSTRALIA AM/FM RADIO FREQ WITH NO PROBLEMS.
DEHP800PRS
Pioneer Premier DEH-P800PRS CD Receiver with High Quality Audio Design and Copper Plated Chassis Model
DEHP800PRS Part No. DEHP800PRS
Supertuner III
24-Station/6-Button (18FM/6AM) Presets
BSM (Best Stations Memory)
Local Station Setting Selectable (4-Step)
Digital Radio Capability:
HD Radio Ready External Control Only
XM Radio Ready:(GEX-P920XM Required)
Sirius Radio Ready: (CDSB10/SCC1 Required)
CD Player:
1-bit D/A Converter 24-bit Burr Brown
CD-R/CD-RW Compatible
AGC (Automatic Gain Control)
Disc Title Memory
Disc List
Track Title List
CD Text CD Text
MP3 Playback Compatibility
Codec Support MP3, WMA, WAV, iTunes AAC
Bluetooth Capable:(CD-BTB200 required)
iPod Control Capable: (CD-IB100II required)
Additional System Expandability:
IP-Bus System Control
USB Control Capability Adapter (CD-UB100 required)
Multi-CD Control
DVD Control
Display Output
Built-in Auxiliary Input (Rear)
Optional (IP-Bus) Auxilary Input CD-RB10 or CD-RB20 required
External Unit Control 2
Display Features:
Auto Slide Motorized Flap Face
Display Type White Organic EL (OEL)
Dot Matrix OEL Size 160 x 48
Multi-Language: English, French, Spanish
Button (Key) Illumination: Switchable Blue or White
Audio Features:
Built-in Speaker Power MOSFET 50W x 4 (22W x 4 RMS)
Equalizer Dual (L/R) 16-Band Graphic
5 Equalizer Presets
2 User Equalizer Settings
Loudness
Advanced Sound Retriever (ASR)
DSP
Auto-EQ (With Mic Included)
Auto-Time Alignment
Listening Position Selector
BBE Digital
Electronic Balance/Fader
Source Level Adjuster (SLA)
Three-Way Crossover Network
High-Pass Crossover (HPF) 50/63/80/100/ 125/160/200Hz, 0/-6/-12dB/Oct.
Subwoofer Crossover (LPF) 50/63/80/100/ 125/160/200Hz, -6/-12/-18dB/Oct.
RCA Preouts 3 pair (Front, Rear, Sub/Non-Fading)
Preout Voltage & Impedance Hi-Volt (5V), 100 ohm
General Features:
Volume Control Rotary Commander
Operation Mode Rotary Commander
10-Key Card Remote Control
Wired Remote Input
Cellular Mute
Detachable Face Security
Face Case (Included)
    • Bah! I can't see the point in custom number plates at all. I went to the rego office, fished through a box of "premium" plates (the ones that had the "not as tall" option for the front plate) and picked the one that had a 32 in it. That's the limit of the effort and cost I will put into number plates. The only plate that I'd consider paying for would be 2332, but that's not possible here because it already exists from probably 90 years ago, and it would cost a fortune to obtain it, if it were available.
    • After chasing my tail with LS results..... and cheaper than a turbo swap... How confident are you that the dyno is accurate relative to other results? How fast is the car - What MPH does it actually run? Is this similar to what people running this power would expect?
    • Hi mate I am having an identical issue with my 98 R34 GTT. The engie suddenly cuts out under load at about 3-4k, black smoke out exhaust. Almost feels like traction control kicking in. No CEL but still going to check codes later today. Car was sitting in the shed for about 5 months before hand and only idled a few times, took her out with about 1/4 tank, filled up and thats when the issues started happening.  Threw on a spare set of coils/harness and checked plugs which was no help. Recently had fuel pump/filter changed so surely thats not the issue unless condensation in fuel, I just havent had the time to drain it It's running a hi flow turbo, bosch 1000cc injectors, walbro 450L, Z32, Nistune etc... All about 2000km old.
    • I always wonder where the obsession with legal/illegal spacing on number plates in the UK comes from. Because it comes up in comments in every UK-based video I see on youtube. From my point of view all of your plates look a bit odd. Just because there are no markings whatsoever. In Australia we have the state that has to be on it. In Europe you get stamps and state logos. Yours look a bit like a throwaway draft that people then stuck with. And attached with blu tack so that it falls off at the slightest disturbance. Not trying to hate, but it's interesting how things are done in different countries. Do you have to follow a lettering convention when choosing a custom plate?
    • Hybrid sounds like a supercharger... It's half a turbo, with a belt to drive it! Oh wait, they're just called super chargers...
