  • Replies 62
i shotgunned LHS trim already.. but i'm not taking any electrics, switches etc or the inner door cloth trim part...
i.e. just the vinyl >_<
Anypne can buy the rest
oh vikz i forgot to asl you if i could get the RHS undertray?? (air deflector or w/e)
Edited by lankanboiiR34
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
