25GTV Posted May 17, 2009 Share Posted May 17, 2009 As title suggests what is the comp ratio... R34 RB25de neo Link to comment https://www.sau.com.au/forums/topic/270429-r34-rb25de-neo-stock-compression-ratio/ Share on other sites More sharing options...
N-DAWG Posted May 17, 2009 Share Posted May 17, 2009 10:1 Link to comment https://www.sau.com.au/forums/topic/270429-r34-rb25de-neo-stock-compression-ratio/#findComment-4599660 Share on other sites More sharing options...
25GTV Posted May 17, 2009 Author Share Posted May 17, 2009 you sure? Link to comment https://www.sau.com.au/forums/topic/270429-r34-rb25de-neo-stock-compression-ratio/#findComment-4599708 Share on other sites More sharing options...
N-DAWG Posted May 17, 2009 Share Posted May 17, 2009 Google is your friend. http://www.carfolio.com/specifications/mod...car/?car=184327 This page should have all the specs you need to know Scroll down to the bottom part of this page also has specs: http://www.northshoreprestige.com.au/vehic...l=r3425gt#specs RB25DE is 10:1 RB25DET is 9:1 RB26DETT is 8.5:1 Link to comment https://www.sau.com.au/forums/topic/270429-r34-rb25de-neo-stock-compression-ratio/#findComment-4600046 Share on other sites More sharing options...
dori34 Posted May 19, 2009 Share Posted May 19, 2009 interesting... thanks for the info nate Link to comment https://www.sau.com.au/forums/topic/270429-r34-rb25de-neo-stock-compression-ratio/#findComment-4604098 Share on other sites More sharing options...
25GTV Posted May 19, 2009 Author Share Posted May 19, 2009 Its actually 9.48:1. I am sure Link to comment https://www.sau.com.au/forums/topic/270429-r34-rb25de-neo-stock-compression-ratio/#findComment-4604154 Share on other sites More sharing options...
N-DAWG Posted May 19, 2009 Share Posted May 19, 2009 What makes you think it's 9.48:1? Just wondering how you worked it out or where you read it. I done a search on nissan.co.jp using search query: rb25de neo Clicked on the 9th search result: http://www.get-u.com/CATALOG/STAGEA/WC34/0...SPEC/engin.html Translate to English: http://babelfish.yahoo.com/translate_url?d...TrUrl=Translate RB25DE NEO is 10:1 RB25DET NEO is 9:1 RB20DE NEO is 9.5:1 That's coming straight from Nissan. Link to comment https://www.sau.com.au/forums/topic/270429-r34-rb25de-neo-stock-compression-ratio/#findComment-4604296 Share on other sites More sharing options...
25GTV Posted May 20, 2009 Author Share Posted May 20, 2009 Fair enough and that is the info i had found... but i actually measured it whilst it was apart... Link to comment https://www.sau.com.au/forums/topic/270429-r34-rb25de-neo-stock-compression-ratio/#findComment-4606718 Share on other sites More sharing options...
GTS4WD Posted May 20, 2009 Share Posted May 20, 2009 According to the Workshop manual, 10:1 Link to comment https://www.sau.com.au/forums/topic/270429-r34-rb25de-neo-stock-compression-ratio/#findComment-4606724 Share on other sites More sharing options...
