Took these at Little Bay, Sydney.. Im sure most of yous know the location already
If not its near la perouse..
CC welcome as always.. coz thats the only way to improve right??
Canon 40d, with sigma 17-70mm lens. Dont own any other equipment so just gotta use what i have i guess..
Hope you like it. Nothing that special, but thought i share it.. This photography section has been so quite lately dont you think??
Will upload some more later on once i go thru them all.. I did upload two different ones in the may thread too..
Enjoy
ta
Edited by siddr20
https://www.sau.com.au/forums/topic/270458-todays-sunset-shots/
I went with a member whos on jdmforums.. Was like a meet thingy we had planned but no one else showed up lol.. apart from him
He just finished processing his images..
Anyways you can see his pics here:
http://kevin-yiu.com/blog/
Be sure to check it out too :P
ta
Edited by siddr20
OMG that location is awesome.. where is it??
Lovely shots too.. i wanna go there!!
tell me tell me tell me
its here in south australia, at aldinga.
when we were driving there we didnt think we could be able to get on the beach..........but we did! was pretty cool :dry:
Here is 1 i took from my back steps
WOW i love the clouds and the intense colour!! nice!!
when we were driving there we didnt think we could be able to get on the beach..........but we did! was pretty cool :P
If i ever come to SA, i will be sure to check that place out!! hahahh
So did you car get stuck in the sand??
nah we didnt at all.
basically where we were driving it was pretty packed in so we were ok, but if i had gone any closer to the water, or any closer to the dune parts, we would have gotten stuck for sure!
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
