Hey guys just need some help finishing my Rb25det series 1 conversion in my HR31 Coupe
(1) The wiring loom I got had the CAS plug cut off it, I've got a CAS plug off a RB20 silvertop, and a RB20 Redtop, can either of these be spliced on to fit? And how would I find out what colours
etc. wiring diagram
(2) What are these plugs?
(3) what plug do i wire constant power, and ignition into?
thanks in advance for the help guys
Cheers
Chester
Edited by chester_fb
https://www.sau.com.au/forums/topic/270908-help-me-finish-my-rb25-conversion/
i've litterally just finished wiring my rb25 into my s13 however after 40 hours of being awake i'm not in any state to explain it, i'll shoot you a pm tomorrow or if you want pm me your msn addy and i'll explain all on there when i'm not a walking zombie
1) can't help you there.. but anybody who has an rb25 can tell you the pins from their CAS plug
2) 2nd photo..
far right, boost control solenoid (not needed unless u want to go use the stock rb25 solenoid)..
brown box - wiper control
square box - pins should be in my guide in the tutorials section..
far left, can't remember, hard to see properly
    • I was getting anxious with the DVLA not knowing if the paperwork is fine or not, so I rang them. No update had been given, but I  was reassured that providing the box was ticked on the V750 then the application will go through fine. I've been checking the DVLA website pretty much every day, in the hope that it would have been done. Fast forward to Monday 29th  and I was greeted with a new screen on the check, and it finally showed as Taxed and MOT'd, woohoo! The car was in desperate need of a clean, not knowing when this day was coming it was put off. As far as I was concerned I had another 3 weeks  I'm not normally one for using snow foam, but I wanted to give it another try It hasn't cleaned up too bad considering it's 21 years old and lived on a boat for a number of weeks. The personalised number plate is J2 XBK, an illegally spaced number plate would have it read J2X BK. BK could either represent  the colour black or Baker, which is my surname. I filmed the first drive, the Youtube link will be at the end. I used the same driving route I did with the 323F V6 when I had a new exhaust installed, heres a couple of photos A few more since then Youtube video can be viewed here: https://www.youtube.com/watch?v=TjkFHPzjGDw
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
