hey guys got a quick question done a engine swap on a 94 gtr (r32) and she isnt starting. She has fuel pressure but no injector pulse and spark and she has constant power at the cas plug. what would be some things to look for as it is drivin me insane. cheers julz.
https://www.sau.com.au/forums/topic/270933-rb26-not-starting-help-needed/
Engine swap? Like for like? Retained original ignition/ecu electrics? Electrics working OK before swap? Electrical harness/sensors/fuses not farked during major surgery? If ans="yes" to previous four questions get Skyline savvy autospark involved, if ans="no" make ans="yes". If still no go then back to "Skyline savvy autospark". Else keep pushing s#$t uphill.
Hope this helps, best of luck with it all.
Cheers GW :ninja:
Do you have power to the injectors? Do you have power to the coilpacks?
Get yourself a good quality LED test light and probe into the pink trigger wire at the coil pack to see if the ECU is putting out a signal. The fact that you have neither injector pulse or spark usually means it's something to do with the CAS (trigger)
You can check the 1deg and 120deg signal with the test light also.
Turn on the ign and check for power at the cas. Once you know the power feed, the one next to it is the earth, the next is the 120deg signal and the last is the 1deg signal. Could be the other way around on the last two can't remember. But it doesn't matter, as long as you are getting a pulse out of both of those wires while cranking. If you are, then look to the ECU and make sure it's all plugged in correctly.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
    • There is a warning that "this thread is super old" but they ignore that anyway...
    • With 10% Ethanol, we're talking 2-3% fuel consumption difference. The emissions reductions and octane boost in my opinion far outweigh this almost non existent loss.    My tanks sitting at 80%. Luckily that should go down fast as I'm on vacation again for the next two weeks.
