hey guys, this is more of a brainstorming thread than a "help me" thread, but im trying to figure out what the f**k is going on with my system, im running a stock S2 turbo on my R33 gtst, its been tuned to 12 pound with stock ecu, stock injectors, with a fmic, pod and 3 inch exhaust decat system.
Whats happening is in "what it seems" to be just 1st and 2nd gear, when i plant it it just keeps boosting, i pull off when it hits 14 pound, but i have a feeling it will just keep going, now apart from that being a problem in its own, when it boosts PAST 12 pound it feels realy rough and not as smooth as the 1-12 pound spool up you get when i plant it, this worries me ALOT. Im not an expert in the field but to me it feels like its a combination of running lean past 12 pound (which might have something to do with the stock ecu) and a leak or something going wrong that keeps pumping pressure into the turbo.
I am also running a boost controller, and i have turned it down 2x half turns at a time and its still boosting up to 14 (when i back off) even though it was tuned to 12 pound.
I am posting this just after giving the car a drive and after sortov suspecting the worst, i do not want to drive my car the same anymore, im not a hoon or anything but every now and then i give it a squirt.
Does anyone know whats going on with my system!? is there a leak? is it running lean? what is letting the turbo boost past 12 pound?
any help is much apreaciated!
cheers
https://www.sau.com.au/forums/topic/271120-turbo-keeps-boosting/
  • Replies 66
either youve got the controller hooked up wrong and its in unlimited boost mode, ie, nothing is holding, and it just keeps climbing (actuator never opens)
or the boost controller is set too high, and in the other gears or engine load some of the boost bleeds off
either is bad and should be fixed
when did it first occur? or has it always been like that?
check all pipework for the boost controller etc
check the vac lines. check the actuator actually opens
when the boost flies past 12psi the stock computer will activate its self protection
and you may also have the engine detonate when boost exceeds this level
its always been like this since it was tuned, it was tuned by sabbadin so i know its been done right, they checked all the boost controller pipework. how do i check that the actuator opens properly?
Sounds like there is a vacuum hose leak or your boost controller is stuffed. Try removing it and connecting the vacuum hose to the actuator. It should then run at stock boost as per your actuator. If it is still boosting too high then it may be that the actuator itself is stuffed / stuck in the closed position, making infinite boost because there's no wastegate opening to relieve pressure.
i think you could be right with the hose leak somewhere, as for the actuator, we changed the turbo from a S1 to a S2 one, and the same thing is happening, so unless its coincidence that the actuator is faulty i dont reckon the problem lies in the actuator :P
its covered in the nissan r33 service manual, you should download it and check for yourself, well worth a read
you need to get a pnuematic pressure gun thingy and attach it to the actuator, and keep building pressure slowly until the actuator rod moves
it should move around 0.70kgcm2 from memory (its in the service manual, the exact number)
if the rod doesnt move, its failed or broken / damaged etc
if the rod moves freely then your boost controller is mangled, damaged, setup wrong, adjusted incorrectly, or faulty
replace or remove and try again
its unlikely the actuator has failed, as its such as simple and old device
its likely your controller has something wrong, is setup wrong, is set too high or something else
try removing it, the car should run stock boost, around 0.70kgcm2 or +5ish on the stock guage
ok i took a pic of the controller setup
-the red dotted hose comes from the intercooler pipe and into the side of the boost controller
-the teal colored arrow on the controller points inwards into the controller
-the yellow hose is going to the actuator
-the green hose the top of that little gadget is blocked as you can see
-the orangey brown hose goes to one of the pipes under the 2 big pipes shown in the pic, the pipe that it goes to cannot be seen in the pic but its metal and about and inch wide and i think its part of the blow off system
does this setup look right?
Yeah, the solenoid is there, the orangey brown one plugs into it.
The orngey brown is the bleed off, which I thought goes back to the turbo intake.
I think theres a restrictor in the pipes somewhere, possibly in the red one. Check this for flow... I can't be sure...
The setup looks right though.
Did you pull a t piece out of this setup and replace it with the boost controller?
You say it's happening in only 1st and second, but not third or more? Sounds like a boost spike.
if it were a boost spike it wouldnt feel rough or leaky or not sure how to explain it once it passes 12 p
the orengy brown one goes to another pipe wich is the blowoff into the intake i think?
Well you haven't explained yourself very well.
Here's example of creep versus boost.
The boost creeps from 12 to 14 over say 5000rpm.
or it hits 12 at 2500rpm and then spikes to 14 at 2700rpm.
which one is it?
If it's creep, then you need to get a ECU and get a tune. There's a whole lot of explanation and debate as to why, but this is the proven answer. If you need to know why, then search.
If it's a spike, then look for the aforementioned restrictor. The solenoid needs it to control the boost properly, and you don't need it for the boost controller.. Boost controllers tend to spike a little anyway.
Do what ^guilt-toy says and get back to us.
put the pressure gun onto the actuator and test it like paul said to do. Check the reading.
if the actuator rod moves within the specified pressure reading, then I would probably run the vac line directly to the actuator and take the controller out of the loop.
If it runs fine like this, then either the controller is bad, or it's been plumbed incorrectly. First take it to 110 but as I would like to know what happens there too.
which one is it?
i dont realy understant what your trying to say with the boost creep and spikes but this is exactly what happens, I floor it in second for example, and its climbing normaly in psi to 12 pound, it makes a small pause at 12 then continues climbing to 14 pound, it dosent spike instantly from 12 to 14, it just climbs the same it would from 1-12, and as i said, i dont know for sure but i dont think 14 is what it stops at, it could keep climbing but i dont want to try it lol.
i will also try the 3rd gear option mentioned to see what happens, i have given it a little bit of a go but it seemed fine, but i didnt realy reach the higher rpms.
also, i blocked off the orangy brown hose seen in the pic this morning, nothing has changed.
cheers
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
