  • Replies 197
Then better pm the location to all the listed 'patrons' instead of posting it publicly...
you never know the next thing you know 50 cars turn up just to watch, a local resident got alarmed, rang the cops, then TMU will follow a few mins later, lotsa canary stickers for the night.
you never know, shits happens. :-)
Exactly the reason why I will be PMing everyone the two or three days before the shoot :mad:
Friday 26/06/09
19:00 RS73
19:30 Shanusr33
20:00 NZMO
20:30 Ashneel
21:00 RBPOWA
21:30 B3ZA
22:00 blk_sz
22:30 GotOne
23:00 MattD
23:30
Saturday 27/06/09
19:00 eMsta
19:30 krzysiu
20:00 LEANBAC
20:30 Halle
21:00 pharoahs33
21:30 scotty014
22:00
22:30
23:00
23:30
awsome im in, id love to have my car professionally done hopefully i get my new front lip by then.
Friday 26/06/09
19:00 RS73
19:30 Shanusr33
20:00 NZMO
20:30 Ashneel
21:00 RBPOWA
21:30 B3ZA
22:00 blk_sz
22:30 GotOne
23:00 MattD
23:30 Halle
Saturday 27/06/09
19:00 eMsta
19:30 krzysiu
20:00 LEANBAC
20:30
21:00 pharoahs33
21:30 scotty014
22:00
22:30
23:00
23:30
A Birthday came up. thank god its on 2 nytes.
Friday 26/06/09
19:00 RS73
19:30 Shanusr33
20:00 NZMO
20:30 Ashneel
21:00 RBPOWA
21:30 B3ZA
22:00 blk_sz
22:30 GotOne
23:00 MattD
23:30 Halle
Saturday 27/06/09
19:00 eMsta
19:30 krzysiu
20:00 LEANBAC
20:30 abu
21:00 pharoahs33
21:30 scotty014
22:00
22:30
23:00
23:30
Yeah exactly. Also makes it quicker for me to upload too :P
For those that really want them printed at high resolution (A1, A0, even larger...) I offer the high res photos at an additional cost.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
