i need to change my front drivers side bearing, i took the wheel off today but there seems to be a steel cover sort of thing over the front of where the bearing is
how do i access the bearings? do u need to take the caliper and disc off?
has that Bearing cover thing unscrew or do u just knock it out?
its pretty urgent!,
thanks
https://www.sau.com.au/forums/topic/271782-how-to-remove-front-wheel-bearings/
You really need to take the entire hub assy off the lca and upper support.
makes life easier.
i attached a pull apart diagram, the centre are usually a press fit, but im used to 32's.
have fun !!! :) its a shitty job
