  • Replies 70
Posted Images
right Stewy so your old man owns you becuase your his son, right
Stick up for your father, he stuck up for you :P
I think we could all chip in a few coin for a bundle of flowers to the lucky lady? :P
... partly make up for the off topic stuff :)
I have been corrected ... Nene is 15 and a half weeks preggo, not 14 :)
... and it has 10 toes and 10 fingers and a doodle :P !
lol i was just thinkin that last night haha
i was positive they where there for 13 wk scan like 3 weeks ago when we where there for ours haha.
i vote no flowers, gas mask for ben, yes.
better yet, do a group buy and get me one too :P
better yet, do a group buy and get me one too :banana:
Hahaha trust me some of them you really need a gas mask!!!! Oopppps now our little girl is awake again
And once again Congrats guys!!
HEHEHE I'M HAVING A BOY... i even have a pic of his willy :laugh:
Thanks for your congrats.. we are so so happy
Sienna's frowning at that lol :banana: nvvn hb n n n c,x,mmcmx,mcmnjsmjvkfvjdlclvkivkjm <------ love Sienna!!!!!!!!!! :laugh:
Thanks guys! :)
As Nene said, we are totally happy!
The first go kart will be on order soon, after all, i should probably test it out for a few years before the lil guy get in, ya know, for safety's sake :P
You never know, he may be heir to the collection, but i dare say by then it will no doubt be of a higher callibre nissans! lol!
And im with Craig, bulk buy on gasmasks!
Was funny bumping into you at the hospital that time of the morning Craig, we'll see if any of our other appointments line up! haha!
maybe, the stupid poor excuse for a midwife, told us we dont have any further scans :)
seems weird not having any scans at all for the last half on the pregnancy...
the ''fun'' antenatal classes start next tues :P 2 hrs every tues night for a month!
*charges PSP*
*charges PSP*
I dont think she new what she was on about mate, you have more, more frequently the closer to the due date??
We have to book in for our classes still!
thats what we thought!
when we have our next app. hopefully we have someone different and ill ask.
oh btw, go to haggle baby!
i bought i top saying '' I LOVE BOOBIES!'' thought that was pretty cool, he will be wearing that xmas day me thinks!
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
