  • Replies 70
Posted Images
right Stewy so your old man owns you becuase your his son, right
Stick up for your father, he stuck up for you :P
I think we could all chip in a few coin for a bundle of flowers to the lucky lady? :P
... partly make up for the off topic stuff :)
I have been corrected ... Nene is 15 and a half weeks preggo, not 14 :)
... and it has 10 toes and 10 fingers and a doodle :P !
lol i was just thinkin that last night haha
i was positive they where there for 13 wk scan like 3 weeks ago when we where there for ours haha.
i vote no flowers, gas mask for ben, yes.
better yet, do a group buy and get me one too :P
better yet, do a group buy and get me one too :banana:
Hahaha trust me some of them you really need a gas mask!!!! Oopppps now our little girl is awake again
And once again Congrats guys!!
HEHEHE I'M HAVING A BOY... i even have a pic of his willy :laugh:
Thanks for your congrats.. we are so so happy
Sienna's frowning at that lol :banana: nvvn hb n n n c,x,mmcmx,mcmnjsmjvkfvjdlclvkivkjm <------ love Sienna!!!!!!!!!! :laugh:
Thanks guys! :)
As Nene said, we are totally happy!
The first go kart will be on order soon, after all, i should probably test it out for a few years before the lil guy get in, ya know, for safety's sake :P
You never know, he may be heir to the collection, but i dare say by then it will no doubt be of a higher callibre nissans! lol!
And im with Craig, bulk buy on gasmasks!
Was funny bumping into you at the hospital that time of the morning Craig, we'll see if any of our other appointments line up! haha!
maybe, the stupid poor excuse for a midwife, told us we dont have any further scans :)
seems weird not having any scans at all for the last half on the pregnancy...
the ''fun'' antenatal classes start next tues :P 2 hrs every tues night for a month!
*charges PSP*
*charges PSP*
I dont think she new what she was on about mate, you have more, more frequently the closer to the due date??
We have to book in for our classes still!
thats what we thought!
when we have our next app. hopefully we have someone different and ill ask.
oh btw, go to haggle baby!
i bought i top saying '' I LOVE BOOBIES!'' thought that was pretty cool, he will be wearing that xmas day me thinks!
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
