Nardi classic 360mm
please note: this is a used wheel that has been refurbished and retrimmed.
The centre is used, and therefore has a few scratches around bolt holes, which are hidden by the horn bezel
retrimmed in brand new perforated cow leather with red stitching. its fresh as, even has new leather smell
this leather is awesomely soft and grippy.
Red Nardi logo
trk-dv sticker in pictures can be removed at buyers request.
comes with horn bezel thing, as pictured.
asking $250 outright, or $200 with trade in of used Nardi classic or Nardi Sports
Rays aluminium wheel nuts.
slightly used.
long type..
set of 20 with lock nuts.
12 x 1.25 suit Nissan
$160 (these are $230 new on ebay)
all parts located Sydney, northern beaches. postage extra
Hey mate.
Do you have the horn button? If not can you supply one?
If you do I'll take it without the url sticker. How much for postage to melb 3109?
  • 3 weeks later...
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
