Item: 19x8.5, 9.5 Starcorp Kaotics wheels
Website: this and boost
Item Condition: few unnoticable nicks here and there and usual gutter marks. Nothing too serious. Tread is about 60-70%
Reason for Selling: Selling due to wheels upgrade - downsizing to 18's
Price and Payment Conditions: $950 (2000 new from tempe)
Extra Info: 5x114.3 stud pattern.. wheels are on the car atm
Contact Details: 0430 308 640 or pm
https://www.sau.com.au/forums/topic/272220-starcorp-kaotics-19/
aii man im new here btu in ur name thing it says eyelids are u selling some and would they be the silver colour of your car? and how much coz im looking to buy some????? and how much to get em to adelaide?
pm sent lol
aii man i cnt send pm yet havnt made 10 posts lmao grrrr but ye ill buy them jus pm me ur details and ill jus make a few posts tonight so i can message u back n can you please attach a pik:)
thanx
Would you straight swap for some 18" black rims with chrome dish (HR Racing) which are the same widths as these rims?
My rims have no gutter rash on it what so ever, still in immaculate condition
kumho 265 on the rear, nexen 235 on the front ...
Let me know,
I may be interested, depending on what I think after I see your rims in person ..
Cheers
Rohan
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
