I have a stock R31 auto, bought as a daily car so 33 gets a break.
Last week i pulled home realising that it was overheating and it was boiling so much i could hear it spilling into the overflow bottle.
I have done a radiator flush but no change, taken in to radiator place and he reckons its a blocked radiator but when undoing the bleed bolts nothing comes out and all other pipes besides the 2 from the radiator are hot. Also pipes going into heater are pretty dry.
Just after any help as im stumped and dont want to put it into a shop as will cost a fortune in labour.
Am gonna pull it apart on the weekend and check radiator, also pull off all pipes and check thermostat....
If you have had this trouble or can help i would appreciate it.
Thanks
Brad
https://www.sau.com.au/forums/topic/272225-overheating/
If you're mechanically minded best part is to work from your engine back.
I couldn't tell you whats wrong as I can't physically see whats the deal.
Basic elimination brother i'm afraid.
Oh...simple, but...is there coolant going fromt the overflow bottle into the radiator?
I have once found a leaf in my bottle in my van, f**k knows how it got in there, but it caused the coolant to stop flowing out.
Hope that helps.
RJ!
https://www.sau.com.au/forums/topic/272225-overheating/#findComment-4623293
Yeah the water is filtering into the radiator and there isnt any leaks, guess only thing i can do is pull it apart and hope i find something.
Guy at radiator place felt the 2 top pipes and said coz they are hot that the thermostat is fine and that he rackons its a blockage...
The fact that the other pipes coming from the engine arent hot i think it may be something else. The bleed bolts should leak air or coolant right?
https://www.sau.com.au/forums/topic/272225-overheating/#findComment-4623305
my car was doing the same thing i replaced everything. new water pump, thermostat hoses etc etc.. turns out the rad was blocked solid cos i used cheap shit coolant from woolies. i got it cleaned at a rad place and is great. cost me $135 including labour to pull it out etc. take it out urself and take it in tell them the core is blocked you want it strip cleaned. where they take the tanks off and jam a strip of stainless into every core to clean them. i wish i had done that first wouldve saved me a lot of money and heartache.. give it a shot mate
https://www.sau.com.au/forums/topic/272225-overheating/#findComment-4623396
I simple check before your spend any money would be to remove your thermostat... chuck a pot of water on the stove... ideally if have a thermometer you can keep an eye on how hot the water is getting.. place the thermostat in the water and see if it opens.
https://www.sau.com.au/forums/topic/272225-overheating/#findComment-4625047
If you're going to boil the thermostat;
- of course if it doesnt open at all with boiling water its stuffed
- just because it opens in boiling water doesnt necessarily mean its opening at the right temperature. So its best to have the a thermometer. Not sure what the opening temp will be, but i'd guess about 70, definitely less than 85.
You could also just remove the thermostat and go for a drive, tho it will take much longer to get up to temperature, so dont thrash it early.
https://www.sau.com.au/forums/topic/272225-overheating/#findComment-4626191
have the taken the car to get looked at yet??
first of all dont take it anywhere without using a pair of pliers/screw driver and ur garden hose
there should be coolant coming out of ur bleeder screw!!! if there isnt.... put the hose into the radiator until water comes out then refitt the screw.
pull both your radiator hoses off (at engine end) and pump the hose in it full blast and see if u get as much coming out as u are pumping in..... if it seems like ur not, the radiator could be blocked....
put it back together and do the same process on ur two small pipes going to the firewall..... put the interior heater swtich to HOT, take both hoses off from the engine side, pump the hose in one end and see if the same amount of water is coming out the other hose..... if its equal flow then ur heater core isnt blocked....
if both of those looks good, pull ur thermostat out , put it back together minus thermostat.... fill with water and let it bleed the air out then go for a drive and see wot happens....
do that b4 u take it anywhere and post results
https://www.sau.com.au/forums/topic/272225-overheating/#findComment-4626489
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
