The hole in the Ozone layer covers most of the Antartic...
...if you gut your cat, the worldwide sea level will rise by 3.5m... killing 220,000,000 people, and displacing 100,000,000 households.
Removing the material inside your catalytic converter on the other hand...:rofl:
why dont u go to ur local exhaust shop and get them to make u a replacement pipe for the cat
remove the cat, install the new pipe and see the difference.
just dont get pulled over by rta or epa and if so hope to god they dont find the cat missing...........
or u could get an exhaust shop to make u up a fake cat ie.cat surround welded to a straight through pipe.
Originally posted by druzilla32
its funny cuz it actually was my cat that did it :rofl:
I dont know WHY i took a foto of it..
Bloody evil kitten it is
Oh right. I thought you had already removed the insides of your cat-converter... rhetorical question...
ohok.. true... i just felt like hitting something with a hammer.. if i got performance gains out of it 4 my car, then bonus...
I dont think i will worry about it then.. If i cant afford a high flow cat at the moment then i cant afford the fine.
Leave it alone, they get replaced as part of compliance so it won't be clogged up and causing a restriction.
If you gut it you won't get much gain as it won't flow very nice, also the car will be louder and and smelly.
yer i just saw the idea somewhere, i forget where tho.. I just thought i should ask some intellegent ppl b4 i got waving a hammer around..
So il just leave it be then..
But while we are on the topic of cats, do high flow cats improve flow much more then stock ones?
People usually refer to a $10k fine, never heard of it being issued though - so could be an urban myth. In any case, not worth tempting anyway. On many (modern) cars, removing or gutting the cat will only provide a very minimal increase. My car (the one I modify anyway) is not one of those, but it is also not a skyline.
And as noted, don't bother unless you can put up with the stench of fuel inside your car (not pleasant).
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
