hey my car is up for sale
http://www.carsales.com.au/used-cars/priva...id=11DE8F377473
call or msg my mobile netime, if u want more pics pm me of msg me for specifics and ill send em to u :action-smiley-069: cheers for looking
-adrian
https://www.sau.com.au/forums/topic/272380-r32-4door-sa/
i did nock a curb yes, but i ddnt put it into their yard, it did a little bitta rim damage that i got fixed, and id damaged the bush in the castor arm, so i got custom nolathane ones made up for it.
https://www.sau.com.au/forums/topic/272380-r32-4door-sa/#findComment-4625695
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
