hey guys,
quick update.
Riverside Infiniti are sending out the Gaskets. a big thank you to Tony from R.I. as soon as they arrive i will post that the kit is available to collect / post out.
Even though they claim they sent them, they clearly were not in the box when they arrived. So i dont know what has happened. I think they may have misplaced the package with the gaskets.
-mark
  • Replies 46
  • 3 weeks later...
Hey Mark,
Picked up the package from the post office on Monday. Thanks a lot for organising the group buy, fantastic work.
I'll be installing it shortly, together with the grounding kit, which should arrive next week.
  • 5 weeks later...
from my post on 350z tech:
finally got around to installing my thermo spacer kit yesterday quick check all good and took for a moderate drive...maybe a little crisper/strong through the rev range, but nothing earth shattering. Got home tonight and re-did the ECU tricks:
1. throttle valve closed reset
2. Accel pedal released learning
3. idle air volume
4. reset ECU (2x last night did not get the timing right, but the check engine doing it fast --> slow flash wiping memory clean tonight.
Car was hot from a 25km commute home, so this time I though gotta try WOT - afterall that's when the short-comings of the old plennum would've been apparent. Wowwee! different car now with my twin 60mm S/S exhaust + 5/16 Thermo plennum spacer kit. Above 5k rpm WOT I sang 'turbo' as it came on song. What hoot, very worthwhile for $280 and 3 hrs careful install. Not a thing out of place with the kit - other than I added couple more washers myself and used 6 of them for the strut brace bolts as the included bolts do not have integrated washers like the OEM bolts.
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
