filthy hondas;
americans. they suck at just about everything. but they know how to do proper fitment.
risky devil... theyre shit is consistently f**king awesome.
... and more filthy honda.
Edited by scandyflick
just a sample of one of the posts ive used to kill peoples internet on r31skylineclub.com
(this is about 1/6 of 1 of 3 posts)
