guys after some information for people that have run a 15mm-20mm spacer. i need atleast a 15mm spacer for my wheels but i don't wanna go too wide so 15mm will do and at the very most 20mm. i trial fitted a 25mm spacer and it loks like with the 25mm spacer that the nuts that hold the spacer onto the original hub are perfectly hidden within the spacer so mounting the wheel wont be any problem.
would like to know if its the same thing with 15mm-20mm spacers or will something protrude out of the face of the spacer? if yes how to u fix it? don't wana chop off my original studs.
let me know guys. pictures would be good too.
Edited by jakez88
i had to fit 15 mm spacers to my 4stud to get bigger brakes.. had to angle grind old stufs off only way i found my rims would fit , just make sure u use a very strong lock tight and torque the nuts tight wat i did, held up alright for last 8 months
hope that helped muuch
have a look at your wheels most of them have gaps between the stud holes so if its just a couple of mm's then it will sit sweet.
You could shave them off with a grinder.
why dont you just measure how long your existing studs are?
Hey dude,
If your wheels have a recess in them that allows the extra stud length to sit in there then you will be fine, if not all you can do is grind them off.
To cover the whole stud you need to use a spacer that is 25mm or bigger. If you do cut the front studs its not too much of a drama to replace them in the future. It only takes about half an hour to do each side.
Good luck with it :thumbsup:
as mentioned, ur studs will protrude, and most wheels have space for this. my biggest concern would be the little amount of metal thats creating ur new hub, firstly its 15mm of alloy holding ur stud in, and less than 15mm for ur old studs to hold.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
