Got the Sh%#$ with the crap laying around in the shed and spare room, so I went nuts taking pics and want to get rid of the stuff.
Pretty much all this stuff is just make an offer or free. I've got prices in mind for some things, but I'll see what happends.
Stock R33 GTS-t intercooler
http://home.iprimus.com.au/jayson77/parts/cooler.jpg
Stock R33 GTS-t dump + front pipe + heat shield.
Also front pipe piece (pretty dodgy) no back flange - for free !
http://home.iprimus.com.au/jayson77/parts/exh.jpg
Stock R33 GTS-t clutch fan + fan + shroud (shroud has had the top cut slightly) - clutch fan and fan SOLD
Stock paper filter for R33 GTS-t airbox. Only done about 3000km.
http://home.iprimus.com.au/jayson77/parts/filter.jpg
Standard R33 GTS-t Cat converter. Works fine, not clogged etc. - SOLD
Front brake pads for R33 GTS-t – pretty sure they are stock ones. Heaps of meat left on them.
http://home.iprimus.com.au/jayson77/parts/pads.jpg
Interior light from R33 GTS-t. Has slight crack in it.
http://home.iprimus.com.au/jayson77/parts/light.jpg
Misc suspension bits for stock suspension on a R33 GTS-t
http://home.iprimus.com.au/jayson77/parts/susp.jpg
http://home.iprimus.com.au/jayson77/parts/susp1.jpg
90 degree 2 1/2 inch rubber bend. One clap fits it, the other is a bit small. SOLD
Twin air horns - SOLD
2 gold fuse holders, one of is mountable, comes with one 60amp fuse and a few metres of cable.
http://home.iprimus.com.au/jayson77/parts/cable.jpg
27mhz President Adams CB. 40ch, AM SSB, modified for extra power, 7khz slide (moves between channels !).
Pearce-Simpson Cub, 40ch AM only.
SWR + Matcher for 27mhz. Handle upto 100w.
http://home.iprimus.com.au/jayson77/parts/cb.jpg
Electrophone 27mhz CB – probably good for parts (if your keen !)
http://home.iprimus.com.au/jayson77/parts/cb1.jpg
27mhz SWR meter
http://home.iprimus.com.au/jayson77/parts/cb2.jpg
Ultrasonic (or microwave??) module for Moss Alarm. If your good you could modify it to suit different alarms.
http://home.iprimus.com.au/jayson77/parts/ms712.jpg
Spot light – 750,000 candle power !! great for spot light shooting, or blinding the fools that refuse to dip their lights !! - SOLD
Rear (or front! Can’t remember) Lovell sway bar for a Datsun 180b !!! Don’t laugh ! Never used….
http://home.iprimus.com.au/jayson77/parts/sway.jpg
MISC stuff below….
Kenwood home graphic (old).
http://home.iprimus.com.au/jayson77/parts/graphic.jpg
Desktop charger for Nokia 8250. Ear piece for 8250. And never used Nokia 3210 covers.
http://home.iprimus.com.au/jayson77/parts/phone.jpg
Spear gun, double band, two heads - Back for sale
Video sender – sends about 5-10 meters at the most !
http://home.iprimus.com.au/jayson77/parts/video.jpg
¾ yard glass !! used once at 21st. Still has all the packaging…
http://home.iprimus.com.au/jayson77/parts/yard.jpg
Happy to send interstate if REALLY keen !!
J
https://www.sau.com.au/forums/topic/27254-fs-make-an-offer/
White 32 - yepp, the bend will slip straight onto a 2 1/2 inch pipe. The inside diameter of the bend is 64mm. Just note that one clamp fits it, but the other is too small, but I'll throw in both.
No problems about sending it to you COD, can send off Monday lunch time.
Make an offer for it :(
J
https://www.sau.com.au/forums/topic/27254-fs-make-an-offer/#findComment-573757
  • 1 month later...
  • 1 year later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
