Hi guys,
I am still deciding if i should purchase this turbo I saw. Dont know the exact specs but the seller tells me its a 700-800hp garret turbo. What I like to know is how much KW's I could expect atw? Turbo starts kicking in before & after internals? What specific parts are needed for internals if I were to utilise all the power available? And lastly a good workshop that is familiar with skylines to make the manifold and tuning?
Thanks in advance and sorry bout all the questions, just need to make sure if I should go ahead with the purchase.
https://www.sau.com.au/forums/topic/27278-700hp-turbo-setup/
You could have a 700hp turbo that makes boost at 3800rpm or one that doesnt till 4500, you really need to know specs.. internals will allow you to run higher boost and revs, but wont really effect the spool up time of the turbo, but once again depends on what cams, what exhaust, what turbo specs, how much and how big your piping is, what intake you run :(
https://www.sau.com.au/forums/topic/27278-700hp-turbo-setup/#findComment-573429
When anyone selling your something tell you it SHOULD like in your case recon it will make 700hp, usually turns out to be full of shit, the turbo is a truck turbo where u would need a rotor that revs to 10grand to get it to sppol up or is totally farked with farked core and wheel!
But it if is a real 700hp tubro i hope u have 10 grand min to spend of other parts to actually get it to run properly!
Either way i think u r dreaming if u r thinking on putting it on a stock car.
https://www.sau.com.au/forums/topic/27278-700hp-turbo-setup/#findComment-573512
If you are serious about building a big hp car, I would only suggest that you go out and buy a book called Maximum Boost by Corky Bell. Perfect if you are new to the world of forced induction. You will be able to ask the right questions and have a pretty good idea of when someone is pulling your leg.
Just consider too that even circuit cars dont make this much power as it is too much for them, so it would be a waste of time on anything but probably a drag strip.
https://www.sau.com.au/forums/topic/27278-700hp-turbo-setup/#findComment-573603
Thanks for the input.....
The turbo did come from a rotor and the owner reckons its a t5 (watever that is!). Anyways I guess u guys r right, its quite a lot of power as my initial aim was to get 300kw. I have done some calculations and 10K would be roughly wat I need to get this figure if parts r seconhand n not touching the internals.
In the mean time I'll just b patient for the right turbo to come along then.
Thanks again.
https://www.sau.com.au/forums/topic/27278-700hp-turbo-setup/#findComment-575825
Steve,
U think 10K is too low. Ive based most things to b 2nd hand (turbo at least!) and have already included labour. My car is quite stock, the usual mods - exhaust, filter, boost, I/C waiting to b installed. I like to keep the internals stock to achieve close to 280-300Kw. Wat have u done so far? Wat r u getting atw?
https://www.sau.com.au/forums/topic/27278-700hp-turbo-setup/#findComment-578417
700HP is too much for a streetable or track-able skyline. Only good for drag racing - It's all or nuthing. And like Steve says, plan on spending 10-15K on the engine to be able to handle the power - then clutch, then driveline, gearbox, diff, driveshafts, then you got to brake - suspension, handling, tyres.
......and the list goes on !
https://www.sau.com.au/forums/topic/27278-700hp-turbo-setup/#findComment-578448
Well my car was completely stock, so far
HKS 3037S56T
Manifold
Clutch
Cooler (you already have)
ECU
EBC
full exhaust
wastegate
CAI and podbox
Plenum
Wheels
Cradle bushes, and hardmount bushes
castor bushes
Coilovers
strut braces
sway bars
several tunes for different stages, ranging from 200 to 600 a go
Body kit (I justified this cos I wanted a big hole for my cooler)
Cams
Cam gear
Headgasket
A second plenum cos the first didnt deliver
injectors
fuel pump
and a few other bits that dont rate a mention. I had a mate ask me what I had spent on the car to day (before another 1.2k for a plenum, or actually getting the cams and head gasket and new plenum fitted, which looks like it is going to cost 1.5K all up with all the added gaskets, head skimmed etc) and it was just on 30K so already that is closer to 35 (still have brake upgrade to do and camber arms and tyres)
the biggest problem so far is getting the power down - I have 256 at 1 bar, but on 1.2 bar (not sure what it has) I cant get traction in any gear, so I will be buying some rear camber arms and some nitto tyres - hopefully sort it out. I have the head gasket going in this week, hopefully tune next week.
Just a decent turbo set up is going to cost you close to 5K all up, need a decent ecu tuned (2K+), and a good clutch(1.2-1.5+), fuel pump(400 and injectors(1k)
With the mods you have, you may just make it under 10k, but dont count on it - you still have to install the injectors, clutch and fuel pump - there is another 6-700. the above costs are conservative, like everything else the costs always blow out.
Good luck - but I seriously doubt you car will be very driveable with a 700+hp turbo. Much better off going for a good steetable setup.
https://www.sau.com.au/forums/topic/27278-700hp-turbo-setup/#findComment-578530
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
