Hi all,
Anyone know of a good place to get cheap tire re-treads in canberra? Are they safe to use for daily driving? I am trying to avoid getting new tyres now as I am waiting on new (bigger) wheels to come from Japan so I was thinking of maybe some re-treads in the mean time??? Seems like a cheap alternative...
Cheers,
https://www.sau.com.au/forums/topic/273035-tire-re-treads/
I've gotten retread for my mates trailer from Advantage maybe called Central Tyre service in Fyshwick.
Re-treads are bad news tho. I think you are better off with cheap second hand tyres. What size are you after? I might have some here you can have.
https://www.sau.com.au/forums/topic/273035-tire-re-treads/#findComment-4634142
Oh I see. So what makes re-treads bad? Even as a temporary solution?
Im after 245/40/18 btw.
Cheers,
https://www.sau.com.au/forums/topic/273035-tire-re-treads/#findComment-4634341
Cheers,
I have some old school Volk GTC originals that will be going up for sale soon with plenty of tread plus 2 extra tyres. They came on the car from Japan so have some salt water etching on them, needs a bit of TLC.. Looking at around $300 for all 6 tyres, plus the 4 wheels and the spacers to suit R33 GTST's (bolt on spacers, not slipons). Size i think is 17*7.5 Fronts and 17*8.5 Rears.
Edited by sfrizza
https://www.sau.com.au/forums/topic/273035-tire-re-treads/#findComment-4634357
so the tyres arent for 18's?
https://www.sau.com.au/forums/topic/273035-tire-re-treads/#findComment-4634457
Unfortunately not, they are suited to the Volks that they are currently on, which I'm pretty sure were 17s.
(Edit: I just noticed that you have a 34 GTR, so this is probably useless for you, sorry mate.)
Edited by sfrizza
https://www.sau.com.au/forums/topic/273035-tire-re-treads/#findComment-4634562
I tried to find re-treads or re-moulds for my tyres awile back and found no one. Still people doing it for trucks etc but nothing for cars.
I had a great re-mould set on an old car a few years back, very sticky. Unfortunatly the cost of remoulding got so high a new tyre was nearly the same price when you take into account the labour.
https://www.sau.com.au/forums/topic/273035-tire-re-treads/#findComment-4634587
How cheap? Do you reckon they would have tyres to suit 245/40/18's?
No idea - just give them a call - 6228 1428.
Haven't been in there for a couple of years, but back then they did seem to at least have matching pairs of most sizes.
Depends on how fussy you are with having same tyres front and back.
They also had some really weird sh1t like snow tyres :P
https://www.sau.com.au/forums/topic/273035-tire-re-treads/#findComment-4636259
that's exactly why they dont bother making them anymore, they ended up costing more to make so prices went above what cheap chinese tyres cost. surprisingly enough though, we had some brand new re-treads turn up on a car at work a few weeks back..... the guy had bought them 2 days earlier down the coast somewhere and one had already fallen apart and damaged his car on the way up from the coast and the other was about to do the same..... 2 DAYS OLD!!!
i wouldn't touch retreads for anything except trucks. try any tyre shops in your area, most will hang on to decent second hand stuff (we do, ill check tomorrow if we have any 18s)
D.
https://www.sau.com.au/forums/topic/273035-tire-re-treads/#findComment-4644050
your lucky Bullet32 hasn't seen this thread! he'd have given you an earful by now!!!
just get new tyres. that is all.
LOL - I HAVE seen this thread and I am laughing at the thought of 18" re-treads... :P
The reason why re-treads are so hard to find these days is that they arent cost effective anymore. Its almost always easier and cheaper to import/wholesale/retail cheap brands such as "Wanli, Accelera, Achilies" etc. than it is to re-tread or re-mould these days.
If you want cheap tyres and arent to fussed about performance then call Tempe or Ozzy tyres and ask for their cheapest nastiest tyres. :)
P.S. - With most re-treaded tyres you dont really know exactly what you are getting, for example: You could buy a re-treaded Michelin which was rated as 'V' (240kph) or 'Z' (300+kph) speed rating when new but the tread compound/pattern that has been moulded on to the old case is only 'S' (180kph) or 'T' (190kph) rated and there would be NO WAY to know for sure....
The point of the story - avoid buying re-treads.
https://www.sau.com.au/forums/topic/273035-tire-re-treads/#findComment-4657493
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
