Hey Guys, have got a few things for sale, will keep adding to the list as i find more stuff
All this stuff to suit RB26DETT, all brand new
ARP Main Studs $225 inc Freight
ARP rod Bolts $75 inc freight
ACL Race Series Main bearings Std Size $110 inc Freight
ACL race series Conrod bearings Std Size $55 inc freight
Ross tuffbond harmonic balancer Retails for $579, sell for $500 inc freight
R33 GTR Crank, brand new $900 plus Freight
All this stuff still in boxes
More stuff
RB26DETT Block with main girdle/cradle: Has been hot tank cleaned, bored out to 87mm, decked a fraction to tidy up the face of the block. has had the mains girdle/cradle fitted and checked the tunnels for out of round/out of spec(Needs welch plugs fitted). $1000 plus freight
Venolia 87mm forged pistons to suit RB26DETT, Brand new in box, with Nissan Genuine rings ready for fitting. All ciclips/gudgen pins etc there as well. $1300 inc freight
All you guys who want to build a new engine should buy all this stuff, all you need is a set of rods and balance the whole lot and you would have 1 tough bottom end
Will sell the lot for $3800 plus freight. Do the sums guys, parts alone cost me $3700 at trade price, retail would be 35-30% more than that and the block work cost $450, factor in the cost of the block and you are saving a fair bit.
Have got receipts for everything except pistons(Lost it somewhere lol)
Price for the whole lot might be negoitable, depending on who it is and whether they might be interested in buying other stuff off me when it becomes available.
Am also wrecking a damaged White R32 GTR, heap of parts sold but there is still a bit of stuff left. Call or PM me for more details or to put in a request for parts
Thanks,
Michael 0438911374
BUMP
Thanks,
Michael 0438911374
Balancer sold,
The rest of the enigine package will be minus balancer, which leaves total at $330 for the rest of the bits
Thanks
ill take the arp main studs and rod bolts
will also take the acl bearings (would std size be whats used during a rebuild?)
Ok mate, will send through bank details later, std bearings would only suit if you were using brand new parts, if you are using an old crank the crank might be slightly worn and need oversize bearings. Please correspond via mobile as my internet is playing up big time, im writing this back from my mobile phone 0438911374
Im interested in the ACL main bearings if they are standard/standard size.
Yeah mate, they are std ACL Race series bearings, main and rod. Bought them to use with the brand new r33 crank that i also bought and which is also for sale. The other guy is interested in them also, seeings he wrote back first will give him first option, if he doesnt wish to proceed, they are all yours.
Ps My internet is playing up a bit(sattalite broadband) so please forgive me if i dont reply, or even easier, call me on 0438911374
Thanks
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
