as some of you know i am no longer the soul owner of the stagea i purchased a while ago, i have given the car to my parents and they are looking at moving into a smaller wheel so the cost of new tyres arnt as high.
so im selling these as i no longer have a car that requires 5 studs.
wheels are in good condition only slight gutter nicks will come up a treat with a clean
pictures.
tyres will need replacing very soon as they are pretty low on the tread side of things
willing to let these go for $1500
pm will be best contact method,
cheers
Jase
  • 3 weeks later...
  • 1 month later...
prefer have these gone by friday guys, pretty firm on the 1k as im loosing alot of money as it is, if interested i can have these to you by thursday as im on holidays and flying out of sydney on friday, txt me 0406552925 and ill call ya back
  • 1 month later...
bump willing to swap these for a decent set of wheels and tyres around 17", these rims will need new tyres asap getting a 32 hopefully so need these gone to complete sale
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
