I bought a half cut for the engine and wiring loom.
There are heaps of parts left over and they are going cheap
I would like to sell the lot if possible, i will take $600 for all of it or just make an offer and i will get back to you, can send pics if you want also.
Front half of car
2x standard intercoolers
AC compressor and bracket
AC Piping
Dashboard, slight damage
Dash cluster 120,xxx kms
dash support rail
Dash surround
swaybar
RH suspension leg, sports shocks
LH suspension leg, sports shocks
Radiator with shroud
power stering pump
glovebox
All pipng for cabin and window vents
Centre console
Airconditioning/Heater box
Carpet (black)
Damaged bonnet
AND MUCH MORE!!!!
If there is something your after, its probably there, Just ask
Can contact me on 0402558417
https://www.sau.com.au/forums/topic/273352-180sx-half-cut-and-parts/
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
