Just wondering if anyone else is going, I hear the last one was good.
A&B Motorsports
41 Winbourne Rd
Brookvale 2100
www.aandbmotorsports.com
Ph: 9905 9523
Starts at 9am and runs all day with a BBQ for lunch.
Cost is $50, but you get a $50 voucher (to spend on anything in their shop (so essentially it's free).
https://www.sau.com.au/forums/topic/273466-ab-dyno-day-at-brokkvale/
