hey guys
i got an r33 gtst manual with the usual bolt ons
healthy stock rb25det,
3.5 inch turbo back stainless
front mount cooler and water spray
12 psi
4.363 diff gears
i've got a budget of around 1600, looking for a replacement turbo
one option that ive considered is a hypergear high flow
do highflowed stock turbo's make a big difference over the standard t3?
much gain?
normally the rb25 turbo's are limited by the ceramic compressor wheel, so you can;t boost it over 12-14 safely
if i got a high flow, due to it having a steel wheel would i be able to wind it higher than the standard t3?
supporting mods?
i think the efficiency of the turbo peaks out at 18-20 psi
https://www.sau.com.au/forums/topic/273575-rb25-replacement-turbo-high-flow/
  • Replies 43
$1600 could get you a remapped ecu, a high flow fuel pump, high flowed injectors and a Z32 afm.
Hypergear do T3 highflows for $800
high flowed turbo will be good for around 260kw atw's
and yes you can run more pressure than the standard spec turbo
Edited by AFTDRK
hey guys
12 psi
4.363 diff gears
much gain?
supporting mods?
I had a high flow on an RB25/30 and it maxed out on 17psi.
Pushed out 284 rwkw ,974 Nm of torque and full boost at 2800 rpm.
Brutal instant power, nasty wheel spin in 1st and 2nd.
Don't know who flowed it though as I bought the car with it already on. Got 60,000 km's out of it.
Before I did my engine rebuild my RB25 was stock , all but FMIC, Haltech ECU , 500 hp fuel pump and the high flow.
It had 247 fwkw or 190rwkw.
Gotrice is bang on with what's needed though my injectors were stock, but my fuel pressure was high (70 psi ) flat out.
For R33 Turbos I actual recommend use our TR43G2 or TR43i for just $200 extra. your stock R33 worth about $300 once its sold. So you only end up paying about $150 more on a custom dump pipe.
even with a high flowed stock turbo a tune would be necessary?
shouldn't the afm compensate for this? it wouldn't be a huge jump up from the stock turbo
i wouldn't mind going to another turbo
just that the convenience of having everything bolt back up no fabrication needed is there if i get it high flowed
Edited by sriver killer
Pretty sure the car would run on a highflowed turbo but it wouldn't be running very happily. You would need at least a piggy back unit like a Safc to try alter the fuel map to correct for the extra airflow. Even just a highflow is going to be freaking out a stock ECU quite a bit.
when my car was untuned with basic mods like fmic full exhaust etc... i had mine running 12pounds.. with a hypergear highflow... it was running madd!
Now my car tuned with injectors and z32 and pfc... im doing about 240kws..
hmm.. sorry to hijack but has anyone looked into the kkr480? its roughly the same price as a high flow and is a straight swap....
I Had one while back. Definitely not a straight swap mate. Water fittings are different, Dump pipe needs to be custom made, intake pipe is different, I had a boost spike issue after installation. It must be externally gated. Performance wise its not bad.
While I have had no personal experience with KKR turbo's, I would advise against them. If your chasing mild gains a High flow would suit you fine. If you are the sort of person who 6 months down to track is going to want more, then invest your money in some decent supporting mods, then just wait till you have the money and chuck a proper turbo on there. Going cheap now might cost you more in the future if you decide you want more power down the track.
Can run stock ecu on hiflowed turbo's.. however dont be compelled to wind up the wick.. as your compressor would be at least 10mm bigger then the stocker.. which would flow craploads more air.
I myself run a bush bearing hiflow with an rx7 core/exhaust setup and only run 5-6psi. Laggy, but way more hit then my stocker @ 9psi.
Hey there, Yeh you can run your highflow turbo with your stock ecu but beware.... once your boost goes past 12psi..... you will hit R&R and therefore you will require your spark plugs to be gapped at 0.8mm and will start miss firing past 3-4rpm.... it will miss..
    • Johnny is sad now... Because you didn't get Bosch Motorsport ABS.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
