yeah there stiff low shocks that have the sweetest performance. Had no problems and i have never ever had the car even make a chirp from the tires around the corners let alone a slip.
performance 9\10
Comfort 4\10 ...... yeah you gota sacrifice some stuff somewhere to make up for other stuff
  • Replies 41
the shocks say KYB on front and rar but the springs i think are 5zigens. Bilsteins, such expensive but sweet ass suspention.
i was looking into getting ISC, HSD or Nismo.
how are the ISC for handling?
the KYBs are amazing, can take corners at 180 but its just the worst to be comfortable in.
hey guys,
just giving ya an update, well ive bought some kyb excel g front and rears shocks, the rears fit perfectly but today when me and my mate tried to put them on the front they didnt fit... there just slightly different, cause of the awd setup i assume, so now im in abit of a pickle, so all of you guys that have aftermarket shocks on the front of ur gts4's, could you please tell me the exact brand and model of ur shocks? lol, im so tired of messing with the car haha.
cheers guys, any help would be awesome
the actual shock is about an inch too long and cause of that the bumb stops dont fit and the screw thread on the end sticks up too far into the engine bay and the bonnet doesnt shut lol, basically lol. where ur's any special type of kyb shock?
I HAVE THE CAMERA!! :P
i wont need to take stupid phone pictures. What do you want me to take pictures of?
I can get under the car only fractionally as im buying new rims and have a 15" space saver with 3 17" rims everywhere else so its on a lean at the front.
Give me a heads up of what pics yours after?
well what i really wanted to know was just what brand and model ur front shocks are, they seem to be the ones causing all the trouble for me lol, cause i have some kyb excel g shocks right now that dont fit lol, i think there for a gtst tho, the backs fit but the front dont lol.
cheers mate
cheers mate
i don't get it the KYB website says its gts-t suspention R33, 2WD Turbo Coupe Incl. 4WS (Note: Rear Lower Eyering Mount Type) Excl. GTR
that 'Note: Rear Lower Eyering Mount Type' is for us because its suppose to be gts-t.
Stagea's have gts-t suspension........
I have pictures
The only other thing i can do is try get behind the space saver and read for a logo on the other side. Its to dirty to see anything on the side i had to get pics of.
I had to take pictures of the dirty side of my car as i have a space saver on the other side because i destroyed my rim..... Getting new ones but :(
anyways i need to get the CV changed its covered in grease everywhere.
there aftermarket
Its the driver side that's really dirty and everything is covered in grease and dust over that because i haven't gotten the CV fixed. I cant get a good picture on the other side which is clean
I posted picture of my fronts before when i didn't have the space saver on. :)
Hey mate, Here's some info Sydneykid gave me when I was trying to find suspension for my old R33 GTS4.
"What you need is R33GTR front shocks and springs to handle the extra weight of the 4wd system and R33GTST rear shocks and springs to suite the mounting system. I have not seen a decent off the shelf spring and shock set (all 4) that is specifically designed for an R33GTS4
The Group Buy kit for the R33GTS4 has the front and rear Bilstein shock valving matched to the springs, bars and to each other. I spent quite a bit of time getting the items matched up. It is definitely a technically superior system. The ride/handling balance is very good, just a bit sporty but not at all harsh."
That was back in 2005, not sure if his Bilstein suspension kits are still available but send him a message and ask him or just if you need any more info about suspension he's a very helpful and knowledgable member here.
:) i didnt know.
It all makes sense now :D
Thats really annoying because there no way to get anything second hand without buying gts-t and then GTR stuff and your left with two sets of shocks ......
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
